Observer pritya
Uncompressing is not happening with zImage while booting up with u-boot
I am working on microzed 7010 board, I have manualy compiled kernel, u-boot, fsbl, and .bit (vivado). Board is booting well with all setup (without using petalinux). But i have noticed that kernel is not Uncompressing kernel... with zImage nor uImage. whereas i can see bootlogs with that of petalinux's images.
INPUT :
1 . zImage env is
zImage=tftpboot 0x3000000 zImage && tftpboot 0x2A00000 system.dtb && bootz 0x3000000 - 0x2A00000
2 . Boot log is =>
Zynq> run zImage
[2017-10-25 15:57:11
ethernet@e000b000 Waiting for PHY auto negotiation to complete......... TIMEOUT !
[2017-10-25 15:57:15
Zynq> run zImage
[2017-10-25 15:57:22
Using ethernet@e000b000 device
TFTP from server 172.16.9.187; our IP address is 172.16.9.25
Filename 'zImage'.
Load address: 0x3000000
    Loading:#####################################################################################################################################################################################################################################
3.9 MiB/s
    done
Bytes transferred = 3913840 (3bb870 hex)
    Filename 'system.dtb'.
    Load address: 0x2a00000
    Loading: #
    3.3 MiB/s
    done
Bytes transferred = 13644 (354c hex)
    Kernel image @ 0x3000000 [ 0x000000 - 0x3bb870 ]
## Flattened Device Tree blob at 02a00000
    Booting using the fdt blob at 0x2a00000
    Loading Device Tree to 1fff9000, end 1ffff54b ... OK
    Starting kernel ...
    Linux version 4.6.0-xilinx-00003-g2762bc9 (pritam@pritam) (gcc version 5.2.1 20151005 (Linaro GCC 5.2-2015.11-2) ) #3 SMP PREEMPT Wed Oct 25 10:28:387
    [2017-10-25 15:57:24
3 . In u-boot I have given bootz support
4 . uImage is formed by
mkimage -A arm -O linux -T kernel -C none -a 0x10000000 -e 0x10000000 -n "Linux kernel" -d arch/arm/boot/zImage uImage
What causing it not to uncompress kernel ? Is u-boot compressing the kernel and booting ?
Any help will be appreciated.
Thanks and regards, Pritam
Voyager
Voyager
Re: Uncompressing is not happening with zImage while booting up with u-boot
Hey Pritam,
This message is generated by the Linux Kernel decompressor after u-boot handed off control to the kernel and it depends on the kernel config itself (CONFIG_*_COMPRESS, CONFIG_*_DECOMPRESS) which if enabled, also selects the compressor and decompressor.
What causing it not to uncompress kernel?
Is u-boot compressing the kernel and booting?
The image created for u-boot has '-C none' which means that there will be no compression applied to the u-boot image. This can be changed to available compressions (see -h for details).
Hope this clarifies,
Herbert
-------------- Yes, I do this for fun!
Observer pritya
Thanks for your reply.
