Unhandled fault: external abort on non-line fetch (0x818) at 0xb6f4b010
As part of our exploration of the capabilities of Zynq, we are trying to configure the IPs  using UIO method. Depending on the entries, we had created in system_user.dtsi, there are entries in /sys/class/uio and /dev/uio folder locations and we can access those.  The entry for PL.dtsi is listed below
video_path_framebuffer_new_v_mix_0: v_mix@43c70000 {
compatible = "xlnx,v-mix-3.0";
interrupt-names = "interrupt";
interrupt-parent = <&intc>;
interrupts = <0 29 4>;
reg = <0x43c70000 0x10000>;
xlnx,s-axi-ctrl-addr-width = <0xc>;
xlnx,s-axi-ctrl-data-width = <0x20>;
In system_user.dtsi, the entry is
/include/ "system-conf.dtsi"
video_path_axis_switch_0 {
compatible = "generic-uio";
reg = <0x43c10000 0x10000>;
video_path_hdmi_out_vtg{
reg = <0x43c50000 0x10000>;
video_path_sensor0_axi_vdma_0{
reg = <0x43000000 0x10000>;
video_path_framebuffer_new_v_mix_0{
This video_path_framebuffer_new_v_mix_0 entry cannot be accessed from devmem as well /dev/uio and throws an error saying Unhandled fault: external abort on non-line fetcg (0x818) at 0xb6f4b010.
  1. What causes this error?
  2. What is the significance of these numbers?
  3. How can this be fixed?
  4. Running cat /proc/interrupts doesn't show up any entries also. Why so?
  5. We had checked the clock soure in pcw.dtsi and there is an entry for clkc as shown below
&clkc {
fclk-enable = <0xf>;
ps-clk-frequency = <33333333>;
We have attached a screenshpt of the error also.
Re: Unhandled fault: external abort on non-line fetch (0x818) at 0xb6f4b010
Solved and now it works without any issues in a new project.
Hope the project files were corrupted.
