joseer
Update petalinux kernel driver using a patch
I'm working on a project where petalinux 2018.3 is used, and I wonder if I could 'update' a particular driver to a newer tag where some modifications/improvements have been done.
In particular I'm interested to update the CAN driver , I'm having issues with the bitrate setup so after reviewing the change log I realised that a few changes have been made in this sense for the 2019.1 version , so would it possible to update the 2018.3 CAN driver to the 2019.1 version using a patch (diff generated replacing the 2018.3 CAN driver checkout by the 2019.1 CAN ones)?
aravindb
HI @joseer
I suggest you to follow below steps to create & apply a patch, it will work if there is not much kernel dependent changes
1. Download same kernel tag from repository
2. modify your changes and create patch using git
3. follow the steps mentioned in this link :http://www.wiki.xilinx.com/PetaLinux+Yocto+Tips section "Patching the Linux Kernel of a PetaLinux Project "
4. petalinux-build
Or
You can also find the kernel source code in your petalinux project  directory
1. cd build/tmp/work-shared/zcu102-zynqmp/kernel-source/
2. modify changes
3. git add filename ; git commit -m "commit msg"; git format-patch commit-id ; -- Use this commands to create a patch
4. Follow the steps mentioned in this link to apply the patch :http://www.wiki.xilinx.com/PetaLinux+Yocto+Tips section "Patching the Linux Kernel of a PetaLinux Project "
5. petalinux-build
Thanks & regards
Aravind
hokim
Simple patch by diff might not work because the driver code for old kernel might framework(subsystem)  functions  outdated in new kernel
aravindb
HI @joseer
4. petalinux-build
Or
2. modify changes
5. petalinux-build
Thanks & regards
Aravind
joseer
Hi @hokim  and @aravindb , thanks for your answers, I'll try to apply the patch as suggested and see if that works.
