joseer
Voyager
Voyager
Using Gstreamer in SDK
I'm trying to develop an application which uses gstreamer library in SDK, but I don't find the way to add properly the paths.
What I've done so far:
- Build petalinux with the gstreamer library and populate sdk sysroot folder.
- Add sysroot folder path to project settings-> miscellaneous:
--sysroot="/home/user/hdl/dev/Petalinux/uz7ev_evcc_sd_oob_2018_2/images/linux/sdk/sysroots/aarch64-xilinx-linux"
- Add paths to "Directories" and "Libraries" in project settings:
Everything builds fine till I added the next function:
gst_app_src_set_caps(GST_APP_SRC(appsrc), caps);
I've got the next error:
/home/user/hdl/dev/src/sdk/vlu2_ximea_gstreamer_test/Debug/../src/CameraTest.c:90: undefined reference to `GST_APP_SRC'
makefile:36: recipe for target 'vlu2_ximea_gstreamer_test.elf' failed
/home/user/hdl/dev/src/sdk/vlu2_ximea_gstreamer_test/Debug/../src/CameraTest.c:90: undefined reference to `gst_app_src_set_caps'
The weird thing is that if I click on  "GST_APP_SRC" or "gst_app_src_set_caps" goes to the file and I can see they are defined. So I think I've got something wrong in the setup or lib paths ....
Does anyone know how to setup properly gstreamer lib to work in SDK?
Thanks in advance.
joseer
Voyager
Voyager
I've finally got it working,  it looks like there's not much information about gstreamer in sdk so I hope this solution helps to someone else in the future.
To fully use gstreamer lib components/plugins in SDK it will be necesary to add the next libraries:
stephenm
Try adding the library too.
Right click on the app, and C/C++ Build Settings:
joseer
Voyager
Voyager
Hi @stephenm , thanks for your reply and suggestion but I forgot to mention that I had already added the libraries:
Gstreamer-1.0
Glib-2.0
and unfortunately it doesn't help...
Any more ideas?
joseer
Voyager
Voyager
stephenm
Great, Thanks for getting back here.
