jgummeson
Using OCM with remoteproc
I have PetaLinux running on UltrasScale MPSoC and I'm using remoteproc to run some code on the RPU. Currently I have memories set up in my device tree that work for running having the RPU code use either the TCM or a reserved region of DDR. Is there a way to use the OCM for code and data when using the remoteproc framework?
When I try linking my RPU code to use the OCM I get this error when I try bringing it up:
remoteproc remoteproc0: bad phdr da 0xfffc0000 mem 0xc6f0
Is there a way to add the OCM to my device tree? This is what my device tree looks like currently for the DDR and TCMs:
        power-domains {
                pd_r5_0: pd_r5_0 {
                        #power-domain-cells = <0x0>;
                        pd-id = <0x7>;
                pd_tcm_0_a: pd_tcm_0_a {
                        pd-id = <0xf>;
                pd_tcm_0_b: pd_tcm_0_b {
                        pd-id = <0x10>;
        amba {
                /* firmware memory nodes */
                r5_0_tcm_a: tcm@ffe00000 {
                        compatible = "mmio-sram";
                        reg = <0x0 0xFFE00000 0x0 0x10000>;
                        pd-handle = <&pd_tcm_0_a>;
                r5_0_tcm_b: tcm@ffe20000 {
                        reg = <0x0 0xFFE20000 0x0 0x10000>;
                        pd-handle = <&pd_tcm_0_b>;
                elf_ddr_0: ddr@3ed00000 {
                        reg = <0x0 0x3ed00000 0x0 0x100000>;
                test_r5_0: zynqmp_r5_rproc@0 {
                        compatible = "xlnx,zynqmp-r5-remoteproc-1.0";
                        reg = <0x0 0xff9a0100 0x0 0x100>,
                        <0x0 0xff9a0000 0x0 0x100>;
                        reg-names = "rpu_base", "rpu_glbl_base";
                        dma-ranges;
                        core_conf = "split0";
                        srams = <&r5_0_tcm_a &r5_0_tcm_b &elf_ddr_0>;
                        pd-handle = <&pd_r5_0>;
Appreciate any help.
jgummeson
Ok, it works now by adding the OCM to system-user.dtsi:
r5_0_ocm: ocm@fffc0000 {
                        reg = <0x0 0xFFFC0000 0x0 0x40000>;
And then adding the OCM as an SRAM for the r5 remoteproc:
                        dma-ranges;
                        srams = <&r5_0_tcm_a &r5_0_tcm_b &elf_ddr_0 &r5_0_ocm>;
So this is working and I can load firmware to the RPU. But do I also need to add the power domain for the OCM? Also, my code does not seem to start up properly if I put .vectors into the OCM. But it works with any/all of the other sections in OCM. Any reason for that? Could it be related to not have the power domain set up for the OCM in the device tree?
mgarrick
I got this working using 2018.3 (using the same fix shown by you).
However, now I need to get it working in 2020.1, and the dtsi is different.
Anyone know how to configure this for 2020.1?
zynqmp-rpu {
#address-cells = <0x00000002>;
#size-cells = <0x00000002>;
ranges;
core_conf = "split";
reg = <0x00000000 0xff9a0000 0x00000000 0x00010000>;
r5@0 {
ranges;
memory-region = <0x00000039 0x0000003a 0x0000003b 0x0000003c>;
pnode-id = <0x00000007>;
mboxes = <0x0000003d 0x00000000 0x0000003d 0x00000001>;
mbox-names = "tx", "rx";
tcm_0@0 {
reg = <0x00000000 0xffe00000 0x00000000 0x00010000>;
pnode-id = <0x0000000f>;
tcm_0@1 {
reg = <0x00000000 0xffe20000 0x00000000 0x00010000>;
pnode-id = <0x00000010>;
I tried adding:
ocm_0@2 {
reg = <0x00000000 0xfffc0000 0x00000000 0x00010000>;
pnode-id = <0x0000000b>;
but it doesn't seem to help.
mgarrick
When I get to loading and releasing the RPU from within Linux, I see the following:
remoteproc remoteproc0: bad phdr da 0xfffc0000 mem 0x228
Which I think means Linux can't access the OCM at 0xFFFC0000.
Anybody got any ideas on how to configure this? Once again, need this in 2020.1
