Using UART/USB for communication in Petalinux on Zybo Z7-10
I am very new to Xilinx SoC, so this may sound bit foolish. I am running a bare minimum Petalinux (2019.2) on a zybo Z7-10. I followed the instructions on ug1144 to build petalinux (no bsp, just a zynq ps in bitstream). Everything is in default configuration. I can both SSH into the petalinux and use GtkTerm to establish serial communication using JTAG port.
What I need to do is to send and receive data over either UART or USB. I have a python program running which is trying to collect data from and send command to an arduino. The data/command is simple string. But when I connect the arduino using JTAG J11 or USB port, it does not show up in /dev/tty*. I first thought that I need to enable the USB in kernel. I tried to search how to do that, but couldn't find a definitive answer. In the kernel config, everything that is mentioned here is selected. I tried to some other solutions like editing the system-top.dts, but didn't work as every time I build petalinux project system-top.dts gets overwritten. I am probably looking at the wrong place and getting more confused.
As an alternative, I was thinking to use PL to do the communication and use a USB-to-TTL converter, but then I found that zybo only has TX/RX in JTAG which can only be used by PS. Is there anyway to establish communication between an arduino and PL? I just need to establish send/receive data from FPGA to arduino, PL or PS doesn't really matter.
Is their any manual or project that I can use to achieve my goal? I am really lost here, and would appreciate any help. Thanks in advance.
Re: Using UART/USB for communication in Petalinux on Zybo Z7-10
Have you checked if the usb is set to host mode in the device tree?
Also, changes made to the device tree should be done in system-user.dtsi in project-spec/meta-user/recipes-bsp/device-tree/files.
This will be appended to system-top.dtsi when building.
Try and see if appending this to your system/top.dtsi solves your problem:
	usb_phy0: phy0 {
		compatible = "usb-nop-xceiv";
		#phy-cells = <0>;
		reset-gpios = <&gpio0 7 1>; /* MIO 7, GPIO_ACTIVE_LOW */
&uart1 {
	status = "okay";
&usb0 {
	status = "okay";
	dr_mode = "host";
	usb-phy = <&usb_phy0>;
@joaragjThank you for your reply. I appended your code to system-user.dtsi, but the issue persisted. Nothing is showing up in /dev/tty*. Here is my system-user.dtsi
/include/ "system-conf.dtsi"
	usb_phy0: phy0 {
		#phy-cells = <0>;
&uart1 {
	status = "okay";
&usb0 {
	status = "okay";
	dr_mode = "host";
And here is the system-top.dtsi -
/dts-v1/;
#include "zynq-7000.dtsi"
#include "pcw.dtsi"
	chosen {
		bootargs = "earlycon";
		stdout-path = "serial0:115200n8";
	aliases {
		ethernet0 = &gem0;
		serial0 = &uart1;
		spi0 = &qspi;
	memory {
		device_type = "memory";
		reg = <0x0 0x40000000>;
#include "system-user.dtsi"
Do I need to change anything in the hardware design? It includes a zynq PS with default config.
I have attached some other files present in devic-etree directory after build, in case it helps to understand the scenario.
Any suggestion is much appreciated.
Mentor
Mentor
Hi @smsunny
Would you share the followings, if possible ?
- linux kernel arguments (Confirm serial port setting)
- boot log file (make sure whether exist warning and error or not)
- result of "lsusb" on Zybo Z7-10 (make sure whether exist proper usb driver or not)
@watari Thank for your reply. Here is the output of "lsusb" on Zybo Z7-10 ( I have a Ubuntu desktop connected at UART and a arduino connected at USB) -
Bus 001 Device 001: ID 1d6b:002 Linux Foundation 2.0 root hub
I have attached two files here with kernel arguments and boot log. To make sure I have the correct things (I am very new to Linux, sorry if I made a mess here), here are the commands I used to get these files -
sudo sysctl -a
journalctl -b
One more thing I would like to mention, I measured the voltage of UART and USB port. UART is getting 5V, but the USB is at 0V. So I think that it is almost certainly a driver or enabling issue.
Any help or suggestion is appreciated.
Mentor
Mentor
Hi @smsunny
What gadget name are you using ?
It might be broken...
@watari please pardon my ignorence, what did you mean by gadget name?
Mentor
Mentor
Hi @smsunny
Would you explain detail about "USB-to-TTL converter" ?
I guess you use some gadget ex. FTDI 232R...
https://dictionary.cambridge.org/us/dictionary/english/gadget
@watari Using a "USB-to-TTL converter" is an alternate way I was thinking. I have this converter, but I am not currently using that. I am currently trying to connect a USB 2.0 cable coming from an arduino to the USB port on my zybo z7-10. If this doesn't work, I am open to using the converter instead. But I am not sure how to do that either, as I would need to access RX/TX pin, which is only available to the PS.
