Using UIO with custom IP
I have created a custom IP module and I want to use UIO. I have been told that the device tree for the module should contain
compatible = "generic-uio";
but mine has
compatible = "xlnx, name_of_module";
So how do I fix this? Also is there anything else I need to do when I configure using Petalinux?
Re: Using UIO with custom IP
You need to modify the device tree, it's not going to happen automatically. Please review UG1144 to see how you can modify system-user.dtsi.
The wiki also has info on modifying the device tree: http://www.wiki.xilinx.com/Device+Tree+Tips
And this wiki page discusses UIO specifically: http://www.wiki.xilinx.com/Testing+UIO+with+Interrupt+on+Zynq+Ultrascale
Also, searching this forum for "generic-uio" provides several pages of results.
Terry
Terry
