Using Vivado 2017.4 with Petalinux 2017.1
Has anyone used the Petalinux 2017.1 toolchain and imported a .hdf and .bit built with Vivado 2017.1?
Is this workable?
I see that someone did this with 2016 (https://forums.xilinx.com/t5/Embedded-Linux/Vivado-2017-1-Generated-HDF-file-import-into-Petalinux-2016-4/m-p/761510/highlight/true#M19451)
Thank you!
john
@jwmurray,
Vivado and PetaLinux should be same version.
Sandeep
@jwmurray,
Sandeep
I appreciate the recommendation to use the same version of Vivado and Petalinux because they have been tested together.  However, Xilinx supports using third party tool chains (e.g. gcc5.3.0) for building an operating system to run on top of a Vivado project.  This is well documented in the Petalinux tools.
I have a Vivado .hdf and .bit file from Vivado 2017.4 which defines the FPGA and other hardware.
My challenge is this:  I need to link with a specific third party library that is in binary form only.  That third party library is not provided by Xilinx.  Fine, I have two versions of that third party library
  a. One that is built using the Xilinx Petalinux 2017.1 toolchain
  b. Another that is built using gcc5.3.0
The answer provided says, "Don't use the 2017.1 toolchain."
Just as easily, I can treat the Petalinux 2017.1 toolchain as a third party toolchain to build my Linux distribution or the gcc5.3.0 toolchain.
Using 2017.4 is not an option, so I have to choose 2017.1 or gcc5.3.0.
Unless there is some inherent incapability that was built into the Petalinux 2017.1 toolchain to prevent it from working with the Vivado 2017.4 project, my risk is the same using either gcc5.3.0 as a third party toolchain or Petalinux 2017.1 as a third party toolchain.  To say, "Don't" simply implies that using Petalinux 2017.1 is worse than gcc5.3.0.
I will have to test it both ways.
Thank you for the input.  I will let you know what happens.
