Using axi dma in petalinux
I have already build my petalinux system and it can run on my ZCU104 successfully.
Also, I have packed sdk/sysroot, and in vivado sdk, I can use it to do cross compiler successfully(opencv)
Now I'm trying to call DMA API in Vivado SDK follow the method mention in this page
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842418/Linux+DMA+From+User+Space
In 3.3 Linux kernel APIs, it mentions that
To get the dma_API, you must #include <linux/dma-mapping.h>.  This
provides dma_addr_t and the interfaces described below.
 But I can't find those files or directory, is it should be generated during petalinux-build --sdk?
Right now, I can't find them in sdk/sysroots.
Can anyone give me some hint? thanks
This method is wrong
In order to use dma in userspace the first thing you should do is build a kernel module for dma driver then compile your userspace code
Chapter 4 in the above link is a right example not Chapter 3
