nvl1109
VDMA fsyncsrc in CR register
Hi all,
I'm confusing that the FSYNCSRC bits isn't consistence between Linux VDMA driver and the manual document (PG020).
The driver code using bit[5:6] for FSYNCSRC, but the PG020 said these bits are reserved.
Code: https://github.com/Xilinx/linux-xlnx/blob/master/drivers/dma/xilinx/xilinx_dma.c#L74
Manual :
So which is correct? Thank you.
radheys
In earlier IP versions this field was used to runtime configure FsyncSrcSelect. See https://www.xilinx.com/support/documentation/ip_documentation/axi_vdma/v5_00_a/pg020_axi_vdma.pdf
In the new IP version, the fsync option is IP customization parameter (no more runtime programmable).
Hope that helps.
Radhey
radheys
Hope that helps.
Radhey
