VNC remote desktop client on Ultra96 Petalinux
I am trying to install a VNC client on the Petalinux distribution running on my Ultra96 board.
Does anyone know how to install one? Any VNC-compatible client should work, but I cannot seem to find one in the existing sample image.
In the Chromium browser, I tried to install a RealVNC Chrome extension but that has some compatibility issue with the browser.
On the command-line, I used smart search '*vnc*' to search for one, but no results were returned.
If anyone has tips on how to find, install and run a VNC client on this board, I would greatly appreciate it!
Harnhua
Fast FPGA design optimization at Plunify
Re: VNC remote desktop client on Ultra96 Petalinux
Hi @harnhua,
Add this to <plnx-proj-root>/project-spec/meta-user/conf/petalinuxbsp.conf
IMAGE_INSTALL_append += " tigervnc"
Refer http://tigervnc.org/ http://cgit.openembedded.org/meta-openembedded/tree/meta-oe/recipes-graphics/tigervnc/tigervnc_1.8.0.bb?h=rocko for more details.
Sandeep
Hi @harnhua,
Sandeep
Thank you, we will give this a try.
Harnhua
