VTC drivers
I am seeing two drivers for vtc in petalinux. drivers/media/platform/xilinx/xilinx-vtc.c and drivers/gpu/drm/xilinx/xilinx_vtc.c. I am using vivado 2015.2(vtc 6.1). Which one I should use. What are the differences between them?
Jothi
Re: VTC drivers
Links to description of both the drivers are here:
http://www.wiki.xilinx.com/Linux+Drivers
Re: VTC drivers
So, the harware vtc 6.1 can use either of the drivers?
Re: VTC drivers
From the description and BD - http://www.wiki.xilinx.com/Xilinx+DRM+KMS+driver, it looks like the DRM_KMS drivers can be used. However I would wait for a confirmation.
Anirudh
Re: VTC drivers
The difference would be in the API - use the driver which matches the API the rest of your pipeline and software uses, or will use.   If you're starting from scratch, DRM/KMS is newer.
drivers/gpu/drm/xilinx/xilinx_vtc.c would be the DRM/KMS API
drivers/media/platform/xilinx/xilinx-vtc.c would be the (older) v4l API.
Voyager
Voyager
Re: VTC drivers
Be careful, when you use vtc driver.
When the clk(for video timing) is not running, don't access register.
It causes kernel fault to access register due to axi bus error
You should enable clock before you access vtc register.
https://www.xilinx.com/support/documentation/ip_documentation/v_tc/v6_1/pg016_v_tc.pdf
page 20 describes
"If the clk signal is not running, the AXI4-Lite interface asserts the slave error response (0x2) for all addresses."
