Valgrind on Petalinux 2016.4
I'm trying to install Valgrind for Petalinux 2016.4 for the microZed board (zynq 7000).  I tried to follow this AR, but couldn't find the option in any of the menuconfigs.  Has this option been removed?
https://www.xilinx.com/support/answers/63280.html
Re: Valgrind on Petalinux 2016.4
Figured it out:
Edit {project_top}/build/conf/local.conf
add "EXTRA_IMAGE_FEATURES = 'tools-profile' " (not the double qoutes)
See this for other options:
https://github.com/Xilinx/meta-petalinux/blob/master/conf/local.conf.sample
hi,
    The AR using buildroot  to build rootfs,not petalinux.
I should have worded it differently.
How do I, using Petalinux 2016.4 tools (e.g yocto), build in Valgrind to my image?
Or, does someone have instructions for how to cross-compile it separately?
This is for petalinux 2015.4, but it might help shed some light on your problem:
https://forums.xilinx.com/t5/Embedded-Linux/Valgrind-on-Linux-for-Zynq/m-p/695578/highlight/true#M16010
Figured it out:
