xilinx_chenzimu
Variables are cleared during operation
I use the zu3cg chip. The FreeRTOS is running on the A53 processor.when the processor operate the double type variable, sometimes the variable becomes zero. why?
There are many reasons for that, you will have to specify more.
xilinx_chenzimu
my code is like this.
void function()
    double tt;
    unsigned int aa = 1;
    unsigned int bb = 2;
    unsigned int cc = 3;
    tt = /65536;
    tt = +aa;
    tt = -cc;
the function is running in a FreeROTS task. And the FreeRTOS will process a interrupt from FPGA, the interrupt's period is 0.5millisecond. Sometimes the tt will become zero during the operation. Can you list some reasons that may refer to the problem? I will try to fix.
now you can get some help.
First, I'm not sure with FreeRTOS if you need to declare tt static.... I guess not, otherwise all variables should be...
Second, what is tt = /65536? Should it be tt /= 65536?
Third, software is dumber than the dumber programmer (a personal principle). You are adding ints to doubles. Please cast your ints to double.
My guess is in that cryptic (to me) line    tt =/ 65536   you are dividing your value (are you?) but for some reason it does an integer division, so any value below 65k becomes a zero. Extra type casts won't harm. You can force a type to a constant, like     (double)65536.
acidka
Have you thought that can be because you just do some operations with this variable and don't use it anywhere?
xilinx_chenzimu
Thanks for your help.
first, i tryed that, define the tt static. But it not work.
second, i am sorry about that. I made a mistake. It should be tt /= 65536.
third, i will try this method. Cast the ints to double.
xilinx_chenzimu
thanks for your help.
I wrote the function that is not complicated compared with my real program. The program uses the variable.
xilinx_chenzimu
I cast the int to double. But, it still don't work.
Could you list other reasons that may cause this problem?
Thank you very much.
I think instead of:
    tt = /65536;
    tt = +aa;
    tt = -cc;
you mean:
    tt /= (double)65536;
    tt += aa;
    tt -= cc;
Other reason I can think of for tt to be zero is if where you look at it is casted to an int. Because of the values of aa and cc and the division, tt is a small number.
For example, if you use something like:
printf("tt = %i\n", tt);
instead of %d or %f
