HeroGian91
[Versal] CPU1 failed to come online
I'm writing you because I'm trying to test a petalinux image for Versal VCK190. The problem is that after booting Linux, the second CPU (CPU1) fails to go online:
[    0.059927] smp: Bringing up secondary CPUs ...
[    5.114410] CPU1: failed to come online
[    5.118265] CPU1: failed in unknown state : 0x0
[    5.122858] smp: Brought up 1 node, 1 CPU
[    5.131628] CPU features: detected: 32-bit EL0 Support
[    5.136797] CPU features: detected: CRC32 instructions
[    5.141993] CPU: All CPU(s) started at EL2
I also tryied to wake up CPU1 after boot with no luck:
root@xilinx-vck190-2020_1:~# echo 1 > /sys/devices/system/cpu/cpu1/online
[155174.857617] psci: failed to boot CPU1 (-22)
[155174.861886] CPU1: failed to boot: -22
 This is what I see with xsdb:
     5  APU
        6  Cortex-A72 #0 (Running)
        7  Cortex-A72 #1 (Reset Catch, EL3(S)/A64)
How can I solve the problem?
Tags (2)
aravindb
HI @HeroGian91
I just verified, we can put both  cores online/offline without having any issues.
Here is the logs for your reference:
root@xilinx-vck190-2020_2:~# cat /sys/devices/system/cpu/cpu1/
cpu_capacity crash_notes hotplug/ online regs/ topology/
cpufreq/ crash_notes_size of_node/ power/ subsystem/ uevent
root@xilinx-vck190-2020_2:~# cat /sys/devices/system/cpu/cpu1/online
1
root@xilinx-vck190-2020_2:~# echo 1 > /sys/devices/system/cpu/cpu1/online
root@xilinx-vck190-2020_2:~# cat /sys/devices/system/cpu/cpu0/online
1
1
root@xilinx-vck190-2020_2:~# echo 0 > /sys/devices/system/cpu/cpu1/online
[ 170.262172] CPU1: shutdown
[ 170.264876] psci: CPU1 killed.
[ 176.136218] Detected PIPT I-cache on CPU1
[ 176.140240] GICv3: CPU1: found redistributor 1 region 0:0x00000000f90a0000
[ 176.147128] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
xsdb% connect
tcfchan#0
xsdb% ta
1 Versal xcvc1902
2 RPU (PS POR is active)
3 Cortex-R5 #0 (PS POR is active)
4 Cortex-R5 #1 (PS POR is active)
5 APU (FPD domain isolation)
6 Cortex-A72 #0 (FPD domain isolation)
7 Cortex-A72 #1 (FPD domain isolation)
8 PPU
9 MicroBlaze PPU (Sleeping after reset)
10 PSM
11 PMC
12 PL
13 DPC
xsdb% ta 6
xsdb% device program BOOT.BIN
100% 10MB 1.3MB/s 00:08
xsdb% ta
1 Versal xcvc1902
2 RPU
3 Cortex-R5 #0 (Halted)
4 Cortex-R5 #1 (Lock Step Mode)
5 APU
6* Cortex-A72 #0 (Running)
7 Cortex-A72 #1 (Running)
8 PPU
9 MicroBlaze PPU (Sleeping)
10 PSM
14 MicroBlaze PSM (Running)
11 PMC
12 PL
13 DPC
In your case, looks Cortex-A72 #1 is reset mode, Can you please just select this core 1 from xsdb console & just run "con" command, it should switch to running state.
I recreated the issue just by resetting the core1 & then again ran the "con" command from xsdb then both cores showing running state.
or you can just cold reboot & cross check once. it should work.
Thanks & regards
Aravind
HeroGian91
Hi @aravindb, thanks for your answer.
I tryied to run CPU1 with xsdb:
xsct% targets
  1* Versal xcvc1902
     2  RPU
     5  APU
     8  PPU
    10  PSM
       11  MicroBlaze PSM (Running)
    12  PMC
    13  PL
 14  DPC
xsct% target 7
xsct% con
Info: Cortex-A72 #1 (target 7) Running
xsct% targets
  1  Versal xcvc1902
     2  RPU
     5  APU
        7* Cortex-A72 #1 (Running)
     8  PPU
    10  PSM
    12  PMC
    13  PL
 14  DPC
xsct%
and then to start the CPU1 also in Linux:
root@vck190:/home/ubuntu# echo 1 > /sys/devices/system/cpu/cpu1/online
[  386.526302] psci: failed to boot CPU1 (-22)
[  386.530489] CPU1: failed to boot: -22
bash: echo: write error: Invalid argument
but CPU1 does not start.
aravindb
HI @HeroGian91
Can you please power off your board & power on again.
Once board is powered on you should be able to see both the cores in running state.
Thanks & regards
Aravind
HeroGian91
I tryied to power off and on the board, and this is what I see:
xsct% targets
  1  Versal xcvc1902
        7* Cortex-A72 #1 (FPD domain isolation)
     8  PPU
    10  PSM
    12  PMC
    13  PL
 14  DPC
when the u-boot is loaded:
xsct% targets
  1  Versal xcvc1902
     2  RPU
     5  APU
        7* Cortex-A72 #1 (Power On Reset)
     8  PPU
    10  PSM
       11  MicroBlaze PSM (Sleeping)
    12  PMC
    13  PL
 14  DPC
when petalinux is started:
xsct% targets
  1  Versal xcvc1902
     2  RPU
     5  APU
        7* Cortex-A72 #1 (Reset Catch, EL3(S)/A64)
     8  PPU
    10  PSM
    12  PMC
    13  PL
 14  DPC
aravindb
Hi @HeroGian91
I just verified with prebuilt images, but i dont see any issues. We can make cpu1 to online.
Also in kernel logs by default we can see both the cpu's are in online (active).
For your reference, I added the dmesg logs below along with cpu status in xsdb console  after booting the petalinux.
Note: I used JTAG boot mode. I would like to know which boot mode you are using. I am just doubting on boot mode. if possible can you please try to use JTAG boot mode & try once.
logs:
[ 0.060982] smp: Bringing up secondary CPUs ...
[ 0.162832] Detected PIPT I-cache on CPU1
[ 0.162855] GICv3: CPU1: found redistributor 1 region 0:0x00000000f90a0000
[ 0.162862] GICv3: CPU1: using allocated LPI pending table @0x00000008f8050000
[ 0.162884] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[ 0.162940] smp: Brought up 1 node, 2 CPUs
[ 0.191977] SMP: Total of 2 processors activated.
[ 0.196732] CPU features: detected: 32-bit EL0 Support
[ 0.201926] CPU features: detected: CRC32 instructions
[ 0.207148] CPU: All CPU(s) started at EL2
[ 0.211296] alternatives: patching kernel code
root@xilinx-vck190-2020_1:~# cat /sys/devices/system/cpu/cpu1/online
1
root@xilinx-vck190-2020_1:~# cat /sys/devices/system/cpu/cpu0/online
1
root@xilinx-vck190-2020_1:~# echo 0 > /sys/devices/system/cpu/cpu1/online
[ 420.551523] CPU1: shutdown
[ 420.554227] psci: CPU1 killed.
[ 734.247478] Detected PIPT I-cache on CPU1
[ 734.251500] GICv3: CPU1: found redistributor 1 region 0:0x00000000f90a0000
[ 734.258388] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
1
xsdb% connect
tcfchan#0
xsdb% ta
1 Versal xcvc1902
8 PPU
10 PSM
11 PMC
12 PL
13 DPC
xsdb% ta 6
xsdb%
xsdb% ta
1 Versal xcvc1902
6* Cortex-A72 #0 (FPD domain isolation)
8 PPU
10 PSM
11 PMC
12 PL
13 DPC
100% 10MB 1.4MB/s 00:07
xsdb% ta
1 Versal xcvc1902
2 RPU
5 APU
8 PPU
10 PSM
11 PMC
12 PL
13 DPC
xsdb%
xsdb% ta
1 Versal xcvc1902
2 RPU
5 APU
7 Cortex-A72 #1 (No Power)
8 PPU
10 PSM
11 PMC
12 PL
13 DPC
xsdb% ta
1 Versal xcvc1902
2 RPU
5 APU
8 PPU
10 PSM
11 PMC
12 PL
13 DPC
xsdb%
Thanks & regards
Aravind
