skaat27
Video Processing Subsystem Linux Drivers
Hello All,
I am using the video processing subsystem IP in my design and would like to know if there are any linux drivers (Petalinux) for the same. I do see the driver here https://www.xilinx.com/support/answers/67375.html, But that is a bare metal one. I am working on petalinux, so it would be easier to have linux drivers.
Karthik
longley
Hi, Karthik,
I am not sure the exact IP driver. But all Linux drivers are listed in this wiki page.
http://www.wiki.xilinx.com/Linux+Drivers
Please check if you can find one.
-Longley
Longley
Versal Blogs
radheys
Hi Karthik,
In addition to what @longley mentioned you can refer below example design which uses VPSS.
http://www.wiki.xilinx.com/Zynq+UltraScale+MPSoC+Base+TRD+2017.2
NOTE: VPSS (scalar only) configuration is supported in linux driver.
https://github.com/Xilinx/linux-xlnx/blob/master/drivers/media/platform/xilinx/xilinx-vpss-scaler.c
Radhey
