Video displayed is slow after the video is scaled through multiscaler
We are using RTSP streaming to stream the video from the IP camera.
The captured video from the IP camera is scaled through Soft scalar using the gstreamer command as shown below:
gst-launch-1.0 rtspsrc location=rtsp://admin:888888@192.168.5.21:5001/udp/av0_0 latency=0 io-mode=4 ! rtph264depay ! h264parse ! queue leaky=2 ! omxh264dec internal-entropy-buffers=3 low-latency=1 ! queue leaky=2 ! videoscale method=0 ! video/x-raw, width=1280, height=720 ! videoconvert ! autovideosink sync=false async=false
Our requirement is to use multiscaler to scale the video. We are using multiscaler linux driver for this purpose. We are using the below gstreamer command for the same.
gst-launch-1.0 rtspsrc location=rtsp://admin:888888@192.168.5.21:5001/udp/av0_1 latency=0 io-mode=4 ! rtph264depay ! h264parse ! omxh264dec ! v4l2video0convert capture-io-mode=4 output-io-mode=4 ! video/x-raw,width=1920,height=1080 ! kmssink bus-id=fd4a0000.zynqmp-display fullscreen-overlay=1 sync=false async=false
We have observed that, the video displayed after soft scaling is as expected. But, the video displayed is slow after scaling through multiscalar.
Could you please suggest on this, to display the video with no delay after using the multiscalar.
With regards,
Ashwini
If you set "sync=true" does Gstreamer complain about dropping frames? What is the message you see?
If so I would recommend you start short-cutting your pipeline to try and figure out what the slow component is. Basically start removing things from the end and start piping them into fakevideosink like:
gst-launch-1.0 rtspsrc location=rtsp://admin:888888@192.168.5.21:5001/udp/av0_1 latency=0 io-mode=4 ! rtph264depay ! h264parse ! omxh264dec ! v4l2video0convert capture-io-mode=4 output-io-mode=4 ! video/x-raw,width=1920,height=1080 ! fakevideosink
 It may also be worth trying a different video source, like videotestsrc to see how frames going into v4l2videoconvert do.
I also assume you are doing this on a part that has a VCU?
Ken Sloat - Embedded Software Engineer
https://www.designlinxhs.com
Hii @ksloatdesignlinx
Thank you for your response.
We have observed that, when we run gst-inspect-1.0 we get the below output:
root@root:~# gst-inspect-1.0 -a | grep xm2msc
[ 82.725905] xilinx-multiscaler a0100000.v_multi: Channel 0 instance created
[ 82.739457] xilinx-multiscaler a0100000.v_multi: Channel 0 instance released
[ 82.746567] xilinx-multiscaler a0100000.v_multi: Channel 1 instance created
[ 82.754651] xilinx-multiscaler a0100000.v_multi: Channel 1 instance released
[ 82.761717] xilinx-multiscaler a0100000.v_multi: Channel 2 instance created
[ 82.769807] xilinx-multiscaler a0100000.v_multi: Channel 2 instance released
[ 82.776862] xilinx-multiscaler a0100000.v_multi: Channel 3 instance created
[ 82.784934] xilinx-multiscaler a0100000.v_multi: Channel 3 instance released
[ 82.791995] xilinx-multiscaler a0100000.v_multi: Channel 4 instance created
[ 82.800082] xilinx-multiscaler a0100000.v_multi: Channel 4 instance released
[ 82.807138] xilinx-multiscaler a0100000.v_multi: Channel 5 instance created
[ 82.815211] xilinx-multiscaler a0100000.v_multi: Channel 5 instance released
[ 82.822265] xilinx-multiscaler a0100000.v_multi: Channel 6 instance created
[ 82.830390] xilinx-multiscaler a0100000.v_multi: Channel 6 instance released
[ 82.837449] xilinx-multiscaler a0100000.v_multi: Channel 7 instance created
[ 82.845421] xilinx-multiscaler a0100000.v_multi: Channel 7 instance released
[ 83.064070] xilinx-multiscaler a0100000.v_multi: Channel 0 instance created
[ 83.076722] xilinx-multiscaler a0100000.v_multi: Channel 0 instance released
[ 83.083780] xilinx-multiscaler a0100000.v_multi: Channel 1 instance created
[ 83.091818] xilinx-multiscaler a0100000.v_multi: Channel 1 instance released
[ 83.098940] xilinx-multiscaler a0100000.v_multi: Channel 2 instance created
[ 83.106949] xilinx-multiscaler a0100000.v_multi: Channel 2 instance released
[ 83.114004] xilinx-multiscaler a0100000.v_multi: Channel 3 instance created
[ 83.122017] xilinx-multiscaler a0100000.v_multi: Channel 3 instance released
[ 83.129071] xilinx-multiscaler a0100000.v_multi: Channel 4 instance created
[ 83.137042] xilinx-multiscaler a0100000.v_multi: Channel 4 instance released
[ 83.144096] xilinx-multiscaler a0100000.v_multi: Channel 5 instance created
[ 83.152074] xilinx-multiscaler a0100000.v_multi: Channel 5 instance released
[ 83.159131] xilinx-multiscaler a0100000.v_multi: Channel 6 instance created
[ 83.167097] xilinx-multiscaler a0100000.v_multi: Channel 6 instance released
[ 83.174152] xilinx-multiscaler a0100000.v_multi: Channel 7 instance created
[ 83.182018] xilinx-multiscaler a0100000.v_multi: Channel 7 instance released
* (gst-inspect-1.0:2657): WARNING *: 13:22:35.024: tried to get connection-id after disabling DTLS
* (gst-inspect-1.0:2657): WARNING *: 13:22:35.029: tried to get connection-id after disabling DTLS
* (gst-inspect-1.0:2657): CRITICAL *: 13:22:36.316: Failed to get connection to xfconfd: Could not connect: Connection refused
But, the expected output is shown below as mentioned in the link
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/75399218/Multi-Scaler+Linux+Driver
v4l2video0convert: String. Default: "xm2msc"
v4l2video1convert: String. Default: "xm2msc"
v4l2video2convert: String. Default: "xm2msc"
v4l2video3convert: String. Default: "xm2msc"
v4l2video4convert: String. Default: "xm2msc"
v4l2video5convert: String. Default: "xm2msc"
v4l2video6convert: String. Default: "xm2msc"
v4l2video7convert: String. Default: "xm2msc"
Could you please give your valuable input on this?
With regards,
Ashwini
What happens if you directly do the following?
gst-inspect-1.0 v4l2video0convert
