Vivado/Petalinux 2017.4 - how to enable x264enc in gstreamer1.0?
I need to build a Petalinux image with gstreamer1.0 supporting the h264 encoding.
I have created my own layer (attached) with:
LICENSE_FLAGS_WHITELIST_append = " commercial"
added in the layer.conf and
IMAGE_INSTALL_append = " gstreamer1.0-plugins-ugly"
IMAGE_INSTALL_append = " x264"
(among others) added in the bbappend file in the recipe.
I can see, that the gstreamer1.0-plugins-ugly is compiled into my image, but without x264enc.
Checking the gstreamer1.0-plugins-ugly.inc in petalinux installation directory
( components/yocto/source/aarch64/layers/core/meta/recipes-multimedia/gstreamer/gstreamer1.0-plugins-ugly.inc )
I can see, that "x264" is not selected in
PACKAGECONFIG ??= " \
    ${GSTREAMER_ORC} \
    a52dec lame mpg123 mpeg2dec \
Of course I can patch it here, but I'd prefer to it on the project level, not system-wide.
How can I modify the setting of the standard package in my own layer?
TIA & Regards,
Wojtek
OK. It was my stupid mistake. It should be
PACKAGECONFIG_append_pn-gstreamer1.0-plugins-ugly = " x264"
in the layer.conf
I attach the corrected layer definition.
Wojtek
I have tried to modify the gstreamer1.0-plugins-ugle package settings using the following methods
(as described e.g., here: https://lists.yoctoproject.org/pipermail/yocto/2015-April/024461.html )
PACKAGECONFIG_pn_gstreamer1.0-plugins-ugly += "  x264"
PACKAGECONFIG_pn_gstreamer1.0-plugins-ugly_append = "  x264"
PACKAGECONFIG_pn_gstreamer1.0-plugins-ugly = "orc  x264"
I have tried to put them into the layer.conf and into the bbappend file, but none of the above worked...
Wojtek
in the layer.conf
Wojtek
