UserJB
Vivado: Vivado cannot write hardware definition as there are no generated IPI blocks
I'm only using Vivado to create the HDF/XSA files so I can build a PetaLinux project.  When I try to export the hardware, I receive this error message:
That's probably true.  I did not create any IP and I don't intend to.  I merely want to get PetaLinux working on the Qemu hardware emulator so I can do development work in PetaLinux.  I don't know anything about FPGA programming.  How can I get past the above problem?
