kevin.jesse
WARNING: Will not program bitstream on the target
Hi Guys,
Even after running
[root@localhost test]# petalinux-package --prebuilt --fpga ./subsystems/linux/hw-description/base_zynq_design_wrapper.bit
INFO: Pre-built directory is updated.
I still can't get the bitstream on the board and it hangs at Petalinux boot hangs on: 'Waiting for PHY auto negotiation to complete..'
Is the bitstream getting put on the board? Is the processor just stopped. I tried starting it as suggested here,
http://forums.xilinx.com/t5/Embedded-Linux/Petalinux-boot-hangs-on-Waiting-for-PHY-auto-negotiation-to/m-p/475328#M9489
but with no such luck. My console output is below
Kevin
kevin.jesse
My solution was to use the BSP and import my project rather than using an empty zynq project.
Kevin
vijayak
Moving to Embedded linux board.
Thanks,Vijay
kevin.jesse
Any followup on this? I'm sure someone has been able to get a vivado project to compile with petalinux AND program the bitstream to the board. What could I be doing wrong??
Kevin
rfs613
Hi Kevin,
There can be many possible causes, but the most common one is having devices listed in the device tree (DTS) which are not actually present. The best way to debug is to enable earlydebug, or alternatively, you can read the kernel log manually via JTAG tools. The steps for the latter are explained here: http://www.wiki.xilinx.com/Debugging+PowerPC+Kernel+Boot+Problems (even though it is for PowerPC, the same process applies on Zynq. You are basically looking for address of the log_buf symbol, and dumping out the memory at that location).
Before resorting to that, I would suggest you try booting with a "minimal" DTS for your board. If you are based of a reference design, try the DTS that came with it, and comment out any of the non-essential peripherals. In particular you might leave out the ethernet interfaces initially. Once you get it booting (or some form of output after "Decompressing linux..." then you can start adding back in devices).
-R
kevin.jesse
Kevin
Anonymous
Not applicable
Kevin
Just rename the bit-stream filename to download.bit, it will work well;
e.g. : if you generate a bitstream file design_wrapper.bit in Vivado, you should modify its name (download.bit) under the directory "pre-built/Linux/implementation"
eliezer
Why does the name of the bitstream matter?
smahalle
No need to change bitstream name
Shubhangi
lperera
I had the same problem,Renaming the bitstream to download.bit solved the problem. I am using petalinux 19.2
details:
I packed using
petalinux-package --prebuilt --fpga    / .  .  . /project_1/project_1.runs/impl_1/design_1_wrapper.bit
thendid a  JTAG boot:
petalinux-boot --jtag --prebuilt 3
This was giving a WARING : Will not program bitstream on the target. If you want to program bitstream, please run petalinux-package --prebuilt to put the bitstream to the prebuitl directory,
renamed pre-built/linux/implementation/design_1_wrapper.bit  to download.bit
Now no warnings and FPGA is programmed in boot up.
aivchenko
The same thing happens in 2020.1.1
Need to "cp ./pre-built/linux/implementation/my_bitstream.bit ./pre-built/linux/implementation/download.bit" then it is loaded into FPGA
