-WPA_SUPPLICANT sh: /usr/local/sbin/wpa_supplicant: No such file or directory
Hello all,
I am working on integrating the ti wilink on my custom unit which is dual core zynq platform. I am using petalinux 2016.4. I followed the instructions from  and also the instructions from one of the forum members to integrate the chip. I see that wilink chip is coming up but now when I try to run the wpa_supplicant or wpa_cli or iw it shows me
-sh: /usr/local/sbin/wpa_supplicant: No such file or directory
I get the same error for all the tools like iw, crda, wpa_cli, wpa_passphrase
Can somebody help me understand why am I getting this error?
I created a install template app and then I changed the .bb file to copy the pre buiilt tools and libraries in the rootfs. I did get the build, it comes up OK but I am seeing the above error:
Machine model: test
bootconsole [earlycon0] enabled
cma: Reserved 16 MiB at 0x3f000000
Memory policy: Data cache writealloc
percpu: Embedded 12 pages/cpu @ef7d2000 s19776 r8192 d21184 u49152
Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 260608
Kernel command line: console=ttyPS0,115200 earlyprintk root=/dev/mmcblk0p2 rw rootwait
PID hash table entries: 4096 (order: 2, 16384 bytes)
Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
Memory: 994028K/1048576K available (6323K kernel code, 240K rwdata, 1980K rodata, 1024K init, 230K bss, 38164K reserved, 16384K cma-reserved, 245760K highmem
Virtual kernel memory layout:
   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
   vmalloc : 0xf0800000 - 0xff800000   ( 240 MB)
   lowmem  : 0xc0000000 - 0xf0000000   ( 768 MB)
   pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
   modules : 0xbf000000 - 0xbfe00000   (  14 MB)
     .text : 0xc0008000 - 0xc091bf34   (9296 kB)
     .init : 0xc0a00000 - 0xc0b00000   (1024 kB)
     .data : 0xc0b00000 - 0xc0b3c3e0   ( 241 kB)
      .bss : 0xc0b3c3e0 - 0xc0b75cfc   ( 231 kB)
       Build-time adjustment of leaf fanout to 32.
       RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=2.
RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=2
NR_IRQS:16 nr_irqs:16 16
efuse mapped to f0802000
slcr mapped to f0804000
L2C: platform modifies aux control register: 0x72360000 -> 0x72760000
L2C: DT/platform modifies aux control register: 0x72360000 -> 0x72760000
L2C-310 erratum 769419 enabled
L2C-310 enabling early BRESP for Cortex-A9
L2C-310 full line of zeros enabled for Cortex-A9
L2C-310 ID prefetch enabled, offset 1 lines
L2C-310 dynamic clock gating enabled, standby mode enabled
L2C-310 cache controller enabled, 8 ways, 512 kB
L2C-310: CACHE_ID 0x410000c8, AUX_CTRL 0x76760001
zynq_clock_init: clkc starts at f0804100
Zynq clock init
sched_clock: 64 bits at 333MHz, resolution 3ns, wraps every 4398046511103ns
clocksource: arm_global_timer: mask: 0xffffffffffffffff max_cycles: 0x4ce07af025, max_idle_ns: 440795209040 ns
Switching to timer-based delay loop, resolution 3ns
clocksource: ttc_clocksource: mask: 0xffff max_cycles: 0xffff, max_idle_ns: 537538477 ns
timer #0 at f080c000, irq=17
Calibrating delay loop (skipped), value calculated using timer frequency.. 666.66 BogoMIPS (lpj=3333333)
Security Framework initialized
Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
Setting up static identity map for 0x100000 - 0x100058
Brought up 2 CPUs
SMP: Total of 2 processors activated (1333.33 BogoMIPS).
CPU: All CPU(s) started in SVC mode.
devtmpfs: initialized
clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
pinctrl core: initialized pinctrl subsystem
DMA: preallocated 256 KiB pool for atomic coherent allocations
cpuidle: using governor menu
zynq-ocm f800c000.ocmc: ZYNQ OCM pool: 256 KiB @ 0xf0880000
zynq-pinctrl 700.pinctrl: zynq pinctrl initialized
GPIO IRQ not connected
XGpio: /amba_pl/gpio@41200000: registered, base is 874
vgaarb: loaded
SCSI subsystem initialized
media: Linux media interface: v0.10
Linux video capture interface: v2.00
pps_core: LinuxPPS API ver. 1 registered
pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
PTP clock support registered
EDAC MC: Ver: 3.0.0
Advanced Linux Sound Architecture Driver Initialized.
clocksource: Switched to clocksource arm_global_timer
TCP established hash table entries: 8192 (order: 3, 32768 bytes)
TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
TCP: Hash tables configured (established 8192 bind 8192)
UDP hash table entries: 512 (order: 2, 16384 bytes)
UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
Freeing initrd memory: 18248K (c6e2e000 - c8000000)
hw perfevents: enabled with armv7_cortex_a9 PMU driver, 7 counters available
futex hash table entries: 512 (order: 3, 32768 bytes)
workingset: timestamp_bits=28 max_order=18 bucket_order=0
jffs2: version 2.2. (NAND) (SUMMARY)  © 2001-2006 Red Hat, Inc.
bounce: pool size: 64 pages
io scheduler noop registered
dma-pl330 f8003000.dmac: Loaded driver for PL330 DMAC-241330
dma-pl330 f8003000.dmac:        DBUFF-128x8bytes Num_Chans-8 Num_Peri-4 Num_Events-16
xilinx-vdma 40400000.dma: Xilinx AXI VDMA Engine Driver Probed!!
e0001000.serial: ttyPS0 at MMIO 0xe0001000 (irq = 143, base_baud = 3125000) is a xuartps
�console [ttyPS0] enabled
bootconsole [earlycon0] disabled
xdevcfg f8007000.devcfg: ioremap 0xf8007000 to f0904000
[drm] Initialized drm 1.1.0 20060810
brd: module loaded
loop: module loaded
m25p80 spi0.0: found n25q256a, expected m25p80
m25p80 spi0.0: n25q256a (32768 Kbytes)
4 ofpart partitions found on MTD device spi0.0
Creating 4 MTD partitions on "spi0.0":
0x000000000000-0x000000500000 : "boot"
0x000000500000-0x000000520000 : "bootenv"
0x000000520000-0x000000fa0000 : "kernel"
0x000000fa0000-0x000002000000 : "spare"
CAN device driver interface
e1000e: Intel(R) PRO/1000 Network Driver - 3.2.6-k
e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
ehci-pci: EHCI PCI platform driver
e0002000.usb supply vbus not found, using dummy regulator
ci_hdrc ci_hdrc.0: unable to init phy: -110
ci_hdrc: probe of ci_hdrc.0 failed with error -110
mousedev: PS/2 mouse device common for all mice
i2c /dev entries driver
EDAC MC: ECC not enabled
Xilinx Zynq CpuIdle Driver started
mmc0: SDHCI controller on e0100000.sdhci [e0100000.sdhci] using DMA
mmc0: new high speed SDHC card at address aaaa
mmcblk0: mmc0:aaaa SL08G 7.40 GiB
mmcblk0: p1 p2
mmc1: SDHCI controller on e0101000.sdhci [e0101000.sdhci] using DMA
ledtrig-cpu: registered to indicate activity on CPUs
usbhid: USB HID core driver
sdhci-arasan e0101000.sdhci: card claims to support voltages below defined range
NET: Registered protocol family 10
sit: IPv6 over IPv4 tunneling driver
can: controller area network core (rev 20120528 abi 9)
mmc1: new high speed SDIO card at address 0001
NET: Registered protocol family 29
can: raw protocol (rev 20120528)
wl18xx_driver wl18xx.0.auto: Direct firmware load for ti-connectivity/wl18xx-conf.bin failed with error -2
can: broadcast manager protocol (rev 20120528 t)
can: netlink gateway (rev 20130117) max_hops=1
hctosys: unable to open rtc device (rtc0)
ALSA device list:
 No soundcards found.
wlcore: ERROR could not get configuration binary ti-connectivity/wl18xx-conf.bin: -2
wlcore: WARNING falling back to default config
Freeing unused kernel memory: 1024K (c0a00000 - c0b00000)
INIT: version 2.88 booting
wlcore: wl18xx HW: 183x or 180x, PG 2.2 (ROM 0x11)
wlcore: loaded
FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
EXT4-fs (mmcblk0p2): recovery complete
EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
random: dd urandom read with 6 bits of entropy available
Mon Oct 16 04:22:56 UTC 2017
Starting internet superserver: inetd.
INIT: Entering runlevel: 5
Configuring network interfaces... ifconfig: SIOCGIFFLAGS: No such device
Starting Dropbear SSH server: Generating key, this may take a while...
Public key portion is:
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQDSF07vI+iNCa5WUK9H7+K4NUmYR+f35DKYSI1DOPZK0oOW4m8OQNF4ckO976Tv6G2x9CJj/hLLDtHEazxCJs9IScamnFo3lZum8PuVSCIR856sKgNjolnZA
UptLyLgCRXHU+tt5NTu7JfiZ6EknYbz9YmXiP6LD9TFvr2Lv2rqfDmCUjFin2Hj/y0LdHYaPN7e8BIRqXgf+of+KJq9dBinhRfEdA+cW2LkFNL4c/dLztiwFICm5orRAl50OHCJmN9u+1qInTQ0ESTDtVOJ6M
qY8K9XG90//ySpOCLE9C5I8vbMsICH0O0eRZox/+/wJW0xZQgqkQ5PLTJ8Sfie8Zt1 root@plnx_arm
Fingerprint: md5 24:47:5f:b0:59:00:33:8d:0f:59:de:68:90:59:fd:99
dropbear.
Starting syslogd/klogd: done
Starting tcf-agent: OK
PetaLinux 2016.4 plnx_arm /dev/ttyPS0
plnx_arm login: root
Password:
root@plnx_arm:~# ifconfig
lo        Link encap:Local Loopback
         inet addr:127.0.0.1  Mask:255.0.0.0
         inet6 addr: ::1%768144/128 Scope:Host
         UP LOOPBACK RUNNING  MTU:65536  Metric:1
         RX packets:0 errors:0 dropped:0 overruns:0 frame:0
         TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
         collisions:0 txqueuelen:1
         RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
root@plnx_arm:~# ifconfig wlan0 up
wlcore: PHY firmware version: Rev 8.2.0.0.237
wlcore: firmware booted (Rev 8.9.0.0.70)
IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
wlan0     Link encap:Ethernet  HWaddr 38:D2:69:B7:A6:76
         UP BROADCAST MULTICAST  MTU:1500  Metric:1
         collisions:0 txqueuelen:1000
root@plnx_arm:~# wpa_supplicant
root@plnx_arm:~#
