Visitor bvcom
Waiting for root device /dev/mmcblk0p2Waiting for root device /dev/mmcblk0p2
i do test on zedboard ,my ubuntu stop @ Waiting for root device /dev/mmcblk0p2Waiting for root device /dev/mmcblk0p2
i want get help?why?
U-Boot 2011.03-00226-gd4000b9-dirty (Jun 19 2012 - 17:52:48)
DRAM: 512 MiB
MMC: SDHCI: 0
Using default environment
In: serial
Out: serial
Err: serial
Net: zynq_gem
Copying Linux from SD to RAM...
Unknown command
Device: SDHCI
Manufacturer ID: 27
OEM: 5048
Tran Speed: 25000000
Rd Block Len: 512
SD version 1.10
High Capacity: Yes
Capacity: 3980394496
Bus Width: 1-bit
reading zImage
2472096 bytes read
reading devicetree.dtb
4197 bytes read
reading ramdisk8M.image.gz
** Unable to read "ramdisk8M.image.gz" from mmc 0:1 **
## Starting application at 0x00008000 ...
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Booting Linux on physical CPU 0
[ 0.000000] Linux version 3.3.0-57645-g78a8fc1 (tinghui.wang@DIGILENT_LINUX) (gcc version 4.6.1 (Sourcery CodeBench Lite 2011.09-50) ) #1 SMP PREEMPT Fri Jun 29 14:54:12 PDT 2012
[ 0.000000] CPU: ARMv7 Processor [413fc090] revision 0 (ARMv7), cr=18c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: Xilinx Zynq Platform, model: Xilinx Zynq ZED
[ 0.000000] bootconsole [earlycon0] enabled
[ 0.000000] Memory policy: ECC disabled, Data cache writealloc
[ 0.000000] BUG: mapping for 0xf8f00000 at 0xfe00c000 out of vmalloc space
[ 0.000000] BUG: mapping for 0xe0001000 at 0xfe001000 out of vmalloc space
[ 0.000000] BUG: mapping for 0xffff1000 at 0xfe200000 out of vmalloc space
[ 0.000000] PERCPU: Embedded 7 pages/cpu @c0920000 s5696 r8192 d14784 u32768
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 125824
[ 0.000000] Kernel command line: console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlyprintk rootfstype=ext4 rootwait devtmpfs.mount=0
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 240MB 256MB = 496MB total
[ 0.000000] Memory: 498068k/498068k available, 26220k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xfd000000 ( 456 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc042bd48 (4240 kB)
[ 0.000000] .init : 0xc042c000 - 0xc0452640 ( 154 kB)
[ 0.000000] .data : 0xc0454000 - 0xc0481bc0 ( 183 kB)
[ 0.000000] .bss : 0xc0481be4 - 0xc0499534 ( 95 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Verbose stalled-CPUs detection is disabled.
[ 0.000000] NR_IRQS:128
[ 0.000000] xlnx,ps7-ttc-1.00.a #0 at 0xe0800000, irq=43
[ 0.000000] Console: colour dummy device 80x30
[ 0.000000] Calibrating delay loop... 1594.16 BogoMIPS (lpj=7970816)
[ 0.090000] pid_max: default: 32768 minimum: 301
[ 0.090000] Mount-cache hash table entries: 512
[ 0.090000] CPU: Testing write buffer coherency: ok
[ 0.090000] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.100000] smp_twd: clock not found: -2
[ 0.100000] Calibrating local timer... 399.33MHz.
[ 0.170000] hw perfevents: enabled with ARMv7 Cortex-A9 PMU driver, 7 counters available
[ 0.170000] Setting up static identity map for 0x2f6110 - 0x2f6144
[ 0.270000] CPU1: Booted secondary processor
[ 0.310000] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.310000] Brought up 2 CPUs
[ 0.310000] SMP: Total of 2 processors activated (3188.32 BogoMIPS).
[ 0.320000] devtmpfs: initialized
[ 0.320000] ------------[ cut here ]------------
[ 0.320000] WARNING: at arch/arm/mm/dma-mapping.c:198 consistent_init+0x70/0x104()
[ 0.330000] Modules linked in:
[ 0.330000] [<c0012920>] (unwind_backtrace+0x0/0xe0) from [<c001ea18>] (warn_slowpath_common+0x4c/0x64)
[ 0.340000] [<c001ea18>] (warn_slowpath_common+0x4c/0x64) from [<c001ea48>] (warn_slowpath_null+0x18/0x1c)
[ 0.350000] [<c001ea48>] (warn_slowpath_null+0x18/0x1c) from [<c04305a8>] (consistent_init+0x70/0x104)
[ 0.360000] [<c04305a8>] (consistent_init+0x70/0x104) from [<c000858c>] (do_one_initcall+0x90/0x160)
[ 0.360000] [<c000858c>] (do_one_initcall+0x90/0x160) from [<c042c85c>] (kernel_init+0x84/0x128)
[ 0.370000] [<c042c85c>] (kernel_init+0x84/0x128) from [<c000dfcc>] (kernel_thread_exit+0x0/0x8)
[ 0.380000] ---[ end trace 1b75b31a2719ed1c ]---
[ 0.380000] ------------[ cut here ]------------
[ 0.390000] WARNING: at arch/arm/mm/dma-mapping.c:198 consistent_init+0x70/0x104()
[ 0.390000] Modules linked in:
[ 0.390000] [<c0012920>] (unwind_backtrace+0x0/0xe0) from [<c001ea18>] (warn_slowpath_common+0x4c/0x64)
[ 0.400000] [<c001ea18>] (warn_slowpath_common+0x4c/0x64) from [<c001ea48>] (warn_slowpath_null+0x18/0x1c)
[ 0.410000] [<c001ea48>] (warn_slowpath_null+0x18/0x1c) from [<c04305a8>] (consistent_init+0x70/0x104)
[ 0.420000] [<c04305a8>] (consistent_init+0x70/0x104) from [<c000858c>] (do_one_initcall+0x90/0x160)
[ 0.430000] [<c000858c>] (do_one_initcall+0x90/0x160) from [<c042c85c>] (kernel_init+0x84/0x128)
[ 0.430000] [<c042c85c>] (kernel_init+0x84/0x128) from [<c000dfcc>] (kernel_thread_exit+0x0/0x8)
[ 0.440000] ---[ end trace 1b75b31a2719ed1d ]---
[ 0.440000] NET: Registered protocol family 16
[ 0.450000] L310 cache controller enabled
[ 0.450000] l2x0: 8 ways, CACHE_ID 0x410000c8, AUX_CTRL 0x72060000, Cache size: 524288 B
[ 0.460000] registering platform device 'pl330' id 0
[ 0.460000] registering platform device 'arm-pmu' id 0
[ 0.470000]
[ 0.470000] ###############################################
[ 0.470000] # #
[ 0.480000] # Board ZED Init #
[ 0.480000] # #
[ 0.490000] ###############################################
[ 0.490000]
[ 0.490000] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[ 0.500000] hw-breakpoint: maximum watchpoint size is 4 bytes.
[ 0.520000] xslcr xslcr.0: at 0xF8000000 mapped to 0xE0808000
[ 0.540000] bio: create slab <bio-0> at 0
[ 0.540000] gpiochip_add: registered GPIOs 0 to 245 on device: xgpiops
[ 0.540000] xgpiops e000a000.gpio: gpio at 0xe000a000 mapped to 0xe080a000
[ 0.550000] status: 10006, mask: 4, value: 0
[ 0.550000] status: 10002, mask: 4, value: 0
[ 0.560000] SCSI subsystem initialized
[ 0.560000] usbcore: registered new interface driver usbfs
[ 0.570000] usbcore: registered new interface driver hub
[ 0.570000] usbcore: registered new device driver usb
[ 0.570000] Advanced Linux Sound Architecture Driver Version 1.0.24.
[ 0.580000] Switching to clocksource xttcpss_timer1
[ 0.590000] NET: Registered protocol family 2
[ 0.590000] IP route cache hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.590000] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[ 0.600000] TCP bind hash table entries: 16384 (order: 5, 196608 bytes)
[ 0.600000] TCP: Hash tables configured (established 16384 bind 16384)
[ 0.610000] TCP reno registered
[ 0.610000] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.620000] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.620000] NET: Registered protocol family 1
[ 0.630000] xscugtimer xscugtimer.0: ioremap fe00c200 to e0810200 with size 400
[ 0.630000] pl330 dev 0 probe success
[ 0.640000] msgmni has been set to 972
[ 0.640000] io scheduler noop registered
[ 0.640000] io scheduler deadline registered
[ 0.650000] io scheduler cfq registered (default)
[ 0.650000] e000▒660000] console [ttyPS0] enabled, bootconsole disabled
[ 0.660000] console [ttyPS0] enabled, bootconsole disabled
[ 0.660000] xdevcfg f8007000.devcfg: ioremap f8007000 to e0814000 with size 1000
[ 0.670000] [drm] Initialized drm 1.1.0 20060810
[ 0.680000] brd: module loaded
[ 0.690000] loop: module loaded
[ 0.690000] xqspips e000d000.spi: at 0xE000D000 mapped to 0xE0816000, irq=51
[ 0.700000] GEM: BASEADDRESS hw: e000b000 virt: e0818000
[ 0.710000] XEMACPS mii bus: probed
[ 0.710000] GEM: MAC addr 00:0a:35:00:01:22
[ 0.710000] eth0, pdev->id -1, baseaddr 0xe000b000, irq 54
[ 0.720000] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.720000] usb_hcd_xusbps_probe: No OTG assigned!
[ 0.730000] usb_hcd_xusbps_probe: OTG now assigned!
[ 0.730000] xusbps-ehci xusbps-ehci.0: Xilinx PS USB EHCI Host Controller
[ 0.740000] xusbps-ehci xusbps-ehci.0: new USB bus registered, assigned bus number 1
[ 0.770000] xusbps-ehci xusbps-ehci.0: irq 53, io mem 0x00000000
[ 0.790000] xusbps-ehci xusbps-ehci.0: USB 2.0 started, EHCI 1.00
[ 0.790000] hub 1-0:1.0: USB hub found
[ 0.790000] hub 1-0:1.0: 1 port detected
[ 0.800000] Initializing USB Mass Storage driver...
[ 0.800000] usbcore: registered new interface driver usb-storage
[ 0.810000] USB Mass Storage support registered.
[ 0.810000] Xilinx PS USB Device Controller driver (Apr 01, 2011)
[ 0.820000] mousedev: PS/2 mouse device common for all mice
[ 0.820000] Linux video capture interface: v2.00
[ 0.830000] gspca_main: v2.14.0 registered
[ 0.830000] usbcore: registered new interface driver uvcvideo
[ 0.830000] USB Video Class driver (1.1.1)
[ 0.840000] WDT OF probe
[ 0.840000] xwdtps f8005000.swdt: Xilinx Watchdog Timer at 0xe0836000 with timeout 10 seconds
[ 0.850000] sdhci: Secure Digital Host Controller Interface driver
[ 0.850000] sdhci: Copyright(c) Pierre Ossman
[ 0.860000] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.860000] mmc0: Hardware doesn't specify timeout clock frequency.
[ 0.870000] usbcore: registered new interface driver usbhid
[ 0.870000] usbhid: USB HID core driver
[ 0.870000] pmodoled: VBAT 55
[ 0.880000] pmodoled: VDD 56
[ 0.880000] pmodoled: RES 57
[ 0.880000] pmodoled: DC 58
[ 0.880000] pmodoled: SCLK 59
[ 0.890000] pmodoled: SDIN 60
[ 0.890000] pmodoled: BUS_ID 2
[ 0.890000] pmodoledoled_spi_probe: Probing pmodoled ..........
[ 0.900000] detect: 90 2 1 0
[ 0.900000] No connectors reported connected with modes
[ 0.900000] [drm] Cannot find any crtc or sizes - going 1024x768
[ 0.910000] drivers/gpu/drm/analog/analog_drm_fbdev.c:analog_drm_fbdev_probe[241]
[ 0.930000] Console: switching to colour frame buffer device 128x48
[ 0.950000] fb0: frame buffer device
[ 0.950000] drm: registered panic notifier
[ 0.950000] [drm] Initialized analog_drm 1.0.0 20110530 on minor 0
[ 1.070000] ALSA device list:
[ 1.070000] No soundcards found.
[ 1.080000] TCP cubic registered
[ 1.080000] NET: Registered protocol family 17
[ 1.080000] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[ 1.090000] Registering SWP/SWPB emulation handler
[ 1.090000] registered taskstats version 1
[ 1.100000] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[ 1.100000] Waiting for root device /dev/mmcblk0p2...
Waiting for root device /dev/mmcblk0p2[ 10.930000] detect: 90 2 0 3
Waiting for root device /dev/mmcblk0p2[ 20.960000] detect: 90 2 0 3
[ 30.990000] detect: 90 2 0 3
[ 41.000000] detect: 90 2 0 3
[ 51.020000] detect: 90 2 0 3
[ 61.040000] detect: 90 2 0 3
[ 71.070000] detect: 90 2 0 3
[ 81.080000] detect: 90 2 0 3
[ 91.110000] detect: 90 2 0 3
[ 101.120000] detect: 90 2 0 3
[ 111.150000] detect: 90 2 0 3
Re: Waiting for root device /dev/mmcblk0p2Waiting for root device /dev/mmcblk0p2
This issue is because of Pin identification or Card-Detection Pin for SD /USB device , code located in xxx-board.c file
Please check gpio pin set for Identifying SD card in BSP Code
and place your file system in the same drive
Ex. /dev/sda1 or /dev/mmcblkp0
Thanks & Regards
Satish.G
G Satish Kumar
