Web server example using petalinux on ZC706
Hi All
I'm using petalinux 2016.2 on ZC706 board, I was able to enable busybox/httpd, and I can use browser to access a simple
index.html through the network. And I'm look for an example which my application could control the web page like take user
input and send back to the user? Any example available?
I know there is one for FREERTOS.
Re: Web server example using petalinux on ZC706
thank you all, I will take a look.
@lynn.zhang check out mongoose
https://code.google.com/archive/p/mongoose/
I don't have an example to provide, but I used flask and python to make a web interface on a zcu102. It's surely not as efficient as something using mongoose, but python was fast to develop.
