watari
Professor
Professor
What Linux OS versions will petalinux 2020.2 support ?
Hi all
I already downloaded petalinux 2020.2 and I'd like to install it into proper OS. Especially I know supported CentOS version and necessary packages.
So, I'm looking for "Install Guide 2020.2". But I can't find it.
Would someone inform it ?
rfs613
It seems that UG1144 has not yet been updated for 2020.2 version. I would assume it will be fixed soon.
In the meantime, the Vivado release notes for 2020.2 indicate CentOS 7.4 - 7.8, and 8.2 (64-bit), so i would expect the list for Petalinux to be similar.
florentw
Hi @watari
As @rfs613 mentioned, the UG1144 should be updated for 2020.2 soon. I can still tell you the supported OS for Petalinux 2020.2
Supported OS:
- Red Hat Enterprise Workstation/Server 7.4, 7.5, 7.6, 7.7, 7.8 (64-bit)
- CentOS Workstation/Server 7.4, 7.5, 7.6, 7.7, 7.8 (64-bit)
- Ubuntu Linux Workstation/Server 16.04.5, 16.04.6, 18.04.1, 18.04.2, 18.04.3, 18.04.4 (64-bit)
I believe CentOS 8.2 is not supported. This is coming from the OS supported by the Yocto project:
https://www.yoctoproject.org/docs/1.8/ref-manual/ref-manual.html#detailed-supported-distros
