What do I need to use Linux
What exactly do I need to download to start using Linux? On the Petalinux download page there are a number of packages (some huge). I have a Zynq on a custom board. Thanks
Re: What do I need to use Linux
You need the "Petalinux 201x.x Installer" which matches your Vivado version (for a custom board you need the HDF file from SDK and its version has to match Petalinux). Follow the instructions in UG1144 "Setting up your Environment"
--Kim
--Kim
