dchang3etagen
What does petalinux-build --sdk do and why do you do it?
Documentation just says "Builds SDK. This is optional."
shabbirk
shabbirk
dchang3etagen
Thank you.
Do I understand correctly that the SDK would be used if I wanted to create and compile applications as if I were in petalinux running on the board?
shabbirk
Hi @dchang3etagen
Yes thats correct
Best Regards
Shabbir
