What does petalinux do petalinux-build?
Hi, all!
I don't understand that petalinux-build does. Because petalinux-build is binary file, not script.
Petalinux-build uses bitbake command may be.
I want to more understand to petalinux.
 use <plnx-proj-root>/build/conf/bblayers.conf?
Thank you!
Re: What does petalinux do petalinux-build?
Hi @jrceokura
In short, petalinux-build internally calls bitbake petalinux-user-image, that generates a device tree DTB file, a first stage bootloader (if selected), U-Boot, the Linux kernel, and a root filesystem image. Finally, it generates the necessary boot images
If you want to add any layers to petalinux, then ideally this is the file that you will edit to include the layer
Refer this User guide for more details:-https://www.xilinx.com/support/documentation/sw_manuals/xilinx2018_1/ug1144-petalinux-tools-reference-guide.pdf
Hi @jrceokura
