vicentiu
What happened to UG980?
It's not in DocNav and it's not mentioned in any other documents' Revision History as being merged.
thanks
Vicentiu
xilinxacct
Instructor
Instructor
@vicentiu
A link to it is on this page... https://www.xilinx.com/support/answers/62896.html
Hope this helps
If so, please mark as solution accepted to close this issue. Kudos also welcomed. :-)
chinmays
Hi @vicentiu,
You can also refer to UG1144-Petalinux tools reference guide for the required information for the latest version.
Chinmay
vicentiu
Where did it dissapear after 2014.2?
Was 980 merged into 1144? I noticed that whenever a document was deprecated and merged into another document, it would appear in the Revision History of the new document as "Merged the contents of UGxxxx".
980 isn't mentioned in any other document as being merged.
tmonaghan84
@chinmays  what did happen to UG980 i can only see a version from 2014?, not a single search result from 2019.1
thawee_rfpixels
Could you please confirm if PetaLinux 2014.2 version isthe latest for these docs?
• PetaLinux SDK Application Development Guide (UG981)
• PetaLinux SDK Board Bringup Guide (UG980)
• PetaLinux SDK Firmware Upgrade Guide (UG983)
• PetaLinux SDK Getting Started Guide (UG977)
• PetaLinux SDK Installation Guide (UG976)
• PetaLinux SDK QEMU System Simulation Guide (UG982)
smahalle
Hi @thawee_rfpixels
please refer to this answer record. As per the answer record, all these user guides are archived.
Thanks & Regards,
Shubhangi
vicentiu
Was the content of UG980 merged in another active/current document or was the content deprecated?
smahalle
Hi @vicentiu,
content of UG980 is merged into a ug1144. Please check the link below of ug1144 v2019.2.
https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_2/ug1144-petalinux-tools-reference-guide.pdf
Thanks & Regards,
Shubhangi
