When the MALI 400 userspace binaries for rel-v2017.4 can be available?
Hi experts,
When I download the mali 400 userspace binaries, I found there is no folder for rel-v2017.4?
So I guess it still is not released, and my question is when this rel-v2017.4 can be available?
Cheers,
Zumeng
sandeepg
Hi zumeng.chen@windriver.com,
You can use 2017.3 binaries as there is no changes for 2017.4
Sandeep
sandeepg
Sandeep
OK, I'm trying to use it, thanks~
