jmgrn
Where can I find the microblaze gnu tools?
I tried to follow this manual to cross compile linux kernel
https://www.scribd.com/doc/63732567/Microblaze-Linux-on-Xilinx-ML605
But most files that need to be downloaded from "Git" already expired. So I tried to gather information here and there and find similar files by myself. But straight problems keep coming up, after I solved one, another came up... Could you anyone suggest an updated version of lab manual like this one? (Not tutorials, I really need detailed operation steps as a beginner)
This should be a standard and straight-forward experiment, but all I have been experiencing lately is frustration.
siktap
These are all part of Xilinx installation.
http://www.wiki.xilinx.com/Build+kernel
There is a blog as well but I havent tested it.
http://blog.sarine.nl/2012/04/18/compile-a-cross-compiler-for-microblaze-xilinx/
Sikta
jmgrn
Thanks for your reply.
But the problem is thatmy platform is ML605(virtex6), but one prerequisite in your 1st link is vivado.
As far as I know, vivado only supports Virtex7 and newer devices. Therefore, ML605(Virtex6) can not work with vivado
Also, the source files, I can not use "git clone" to download "device-tree" atall, because that page is already deleted.
I admit that there are more and more vivado users, but I think ML605 (Virtex6) is still not very old. There must be a way to generate corresponding device tree and do the cross-compile.
Could you please suggest some design flows that work for ML605(virtex6) ?
