jrceokura
Where is C library header files (e.g.stdio.h) that Petalinux-build use?
Hi all.
I am porting application from RTOS to petalinux.
In this work, I should compare C library header files.
Because in RTOS has characteristic C library. It may be diffrent to petalinux's.
This diffrencies probably cause bugs.
Therefore I want to read header files.
But I strictly don't know where are. I want to accurate infomation.
Best regard.
jrceokura
I solved this question.
The header file path is "build/tmp/sysroots/plnx_arm".
Best regards.
aravindb
Hi @jrceokura
Please follow the stpes mentioned in ug1144 guide for creating applications in petalinux:https://www.xilinx.com/support/documentation/sw_manuals/xilinx2019_2/ug1144-petalinux-tools-reference-guide.pdf (Section :Creating and Adding Custom Applications)
petalinux-create -t apps --template c --name myapp --enable  -- >This will create an application source code in <plnx-proj-root>/project-spec/
meta-user/recipes-apps/myapp directory , you just need to replace with your own code & build it.
Thanks & regards
Aravind
jrceokura
Hi @aravindb
Thank you for replying, but it's not things I want to know.
I want to know C library header file path. (e.g. stdio.h string.h)
Is it "/usr/include"?
My development machine is ubuntu 16.04 LTS.
My petalinux version is 2017.4.
Best regards.
jrceokura
Best regards.
