vanmierlo
Mentor
Mentor
Where is UG1144
Where has UG1144 PetaLinux Tools Documentation / Reference Guide gone to? I cannot find it anymore. Has it been revoked? Replaced? Misplaced?
achutha
@vanmierlo
Petalinux 2015.2.1 docs are released and you should be able to view are download them.
UG1114 -http://www.xilinx.com/support/documentation/sw_manuals/petalinux2015_2/ug1144-petalinux-tools-reference-guide.pdf
Ram
balkris
you can find here
http://www.xilinx.com/support/documentation/sw_manuals/petalinux2014_4/ug1144-petalinux-tools-reference-guide.pdf
Thanks and Regards
Balkrishan
balkris
attached for you
Thanks and Regards
Balkrishan
vanmierlo
Mentor
Mentor
Is there also a more recent version? I just tried to follow the link to "PetaLinux Downloads" on page 16 and it gives an empty page.
balkris
UG1144 (v2015.2.1) August 25, 2015 is the recent which is not released . I think it will release in couple of days
Thanks and Regards
Balkrishan
achutha
@vanmierlo
Ram
