Window manager in Petalinux
Which window manager is available in Petalinux/Yocto ?
Several are possible:
 - Matchbox/Sato : by default, not for my needs
 - Enlightenment (efl): blacklisted
 - Xfce: could be fine
 - Gnome: many recipes blacklisted.
Is it possible to build gnome or efl with Petalinux v2018.2 ?
Is it possible to use old releases with the last Petalinux (I'm using the Ultra96 BSP of v2018.2) ?
Or is it better not to use Petalinux, and build on the target OS ?
Re: Window manager in Petalinux
Hi @raiatea,
I would suggest to use XFCE for Ultra96.
Sandeep
Hi @raiatea,
Sandeep
