Writing to QSPI flash across all partitions from Linux
I have a Zynq Mini-ITX board with 32MB QSPI on it.
I'm using Linux with mtd-utils.
QSPI can be updated via JTAG by creating partitions for different boot components as described in the UG873 document (http://www.xilinx.com/support/documentation/sw_manuals/xilinx14_7/ug873-zynq-ctt.pdf, section 5.2.5).
It creates a single BOOT.mcs file as a QSPI partition.
On bootup, it finds all the partitions correctly:
[ 1.040691] 7 ofpart partitions found on MTD device spi0.0
[ 1.046097] Creating 7 MTD partitions on "spi0.0":
[ 1.050991] 0x000000000000-0x0000000e0000 : "qspi-fsbl"
[ 1.063582] 0x0000000e0000-0x000000100000 : "qspi-ubootenv"
[ 1.074164] 0x000000100000-0x000000dc0000 : "qspi-bitstream"
[ 1.084411] 0x000000dc0000-0x000000fe0000 : "qspi-uboot"
[ 1.094426] 0x000000fe0000-0x000001400000 : "qspi-linux"
[ 1.104394] 0x000001400000-0x000001420000 : "qspi-device-tree"
[ 1.115015] 0x000001420000-0x000001a80000 : "qspi-rootfs"
I can updated a partition by: flashcp -v fsbl.elf /dev/mtd0
Is there any way to update the whole QSPI flash device (across all partitions) within Linux with a single image file?
(For comparison, if doing something to a hard disk across the whole device and across all partitions, you would use /dev/hda instead of a specific partition like /dev/hda1. However, /dev/mtd doesn't exist)
Tags (4)
