Observer winston
Wrong Image Format for bootm command ERROR: can't get kernel image (ZCU102, Petalinux 2018.1 & SDK 2018.1)
Hi all,
    I have a problem when I boot a ZCU102 board using qspi it hang on the u-boot and it showing like this messages
SF: Detected n25q512a with page size 512 Bytes, erase size 128 KiB, total 128 MiB
device 0 offset 0x140000, size 0x1600000
SF: 23068672 bytes @ 0x140000 Read: OK
   And anybody help me to resolve this issue the log is mentioned below
U-Boot 2018.01 (Jul 09 2018 - 14:39:56 +0530) Xilinx ZynqMP ZCU102 rev1.0
I2C:   ready
DRAM:  4 GiB
EL Level:       EL2
Chip ID:        zu9eg
MMC:   sdhci_send_command: MMC: 0 busy timeout increasing to: 200 ms.
sdhci_send_command: MMC: 0 busy timeout increasing to: 400 ms.
sdhci_send_command: MMC: 0 busy timeout increasing to: 800 ms.
sdhci_send_command: MMC: 0 busy timeout increasing to: 1600 ms.
sdhci_send_command: MMC: 0 busy timeout increasing to: 3200 ms.
sdhci_send_command: MMC: 0 busy timeout.
mmc_init: -70, time 7439
sdhci@ff170000 - probe failed: -70
mmc_init: -70, time 7413
In:    serial@ff000000
Out:   serial@ff000000
Err:   serial@ff000000
Model: ZynqMP ZCU102 Rev1.0
Board: Xilinx ZynqMP
Bootmode: QSPI_MODE
Net:   ZYNQ GEM: ff0e0000, phyaddr c, interface rgmii-id
eth0: ethernet@ff0e0000
U-BOOT for mp-soc-QSPI
ethernet@ff0e0000 Waiting for PHY auto negotiation to complete......................................... TIMEOUT !
Hit any key to stop autoboot:  0
++++++++++ERROR: can't get kernel image+++++++++++++++++++++++!
ZynqMP>
ZynqMP>
ZynqMP>
ZynqMP> pri
arch=arm
autoload=no
baudrate=115200
board=zynqmp
board_name=zynqmp
boot_img=BOOT.BIN
boot_targets=qspi0
bootcmd=run default_bootcmd
bootdelay=4
bootenv=uEnv.txt
bootenvsize=0x40000
bootenvstart=0x100000
bootsize=0x100000
bootstart=0x0
clobstart=0x10000000
console=console=ttyPS0,115200
cp_kernel2ram=sf probe 0 && sf read ${netstart} ${kernelstart} ${kernelsize}
cpu=armv8
default_bootcmd=run cp_kernel2ram && bootm ${netstart}
dfu_mmc_info=set dfu_alt_info ${kernel_image} fat 0 1\\;dfu_mmc=run dfu_mmc_info && dfu 0 mmc 0
dfu_ram=run dfu_ram_info && dfu 0 ram 0
dfu_ram_info=setenv dfu_alt_info image.ub ram $netstart 0x1e00000
dtb_img=system.dtb
dtbnetstart=0x11800000
eraseenv=sf probe 0 && sf erase ${bootenvstart} ${bootenvsize}
ethact=ethernet@ff0e0000
ethaddr=00:0a:35:00:22:01
fault=echo ${img} image size is greater than allocated place - partition ${img} is NOT UPDATED
fdtcontroladdr=7fe7cfd0
importbootenv=echo "Importing environment from SD ..."; env import -t ${loadbootenv_addr} $filesize
install_boot=sf probe 0 && sf erase ${bootstart} ${bootsize} && sf write ${clobstart} ${bootstart} ${filesize}
install_jffs2=sf probe 0 && sf erase ${jffs2start} ${jffs2size} && sf write ${clobstart} ${jffs2start} ${filesize}
install_kernel=sf probe 0 && sf erase ${kernelstart} ${kernelsize} && sf write ${clobstart} ${kernelstart} ${filesize}
jffs2_img=rootfs.jffs2
kernel_img=image.ub
kernelsize=0x1600000
kernelstart=0x140000
load_boot=tftpboot ${clobstart} ${boot_img}
load_dtb=tftpboot ${clobstart} ${dtb_img}
load_jffs2=tftpboot ${clobstart} ${jffs2_img}
load_kernel=tftpboot ${clobstart} ${kernel_img}
loadaddr=0x10000000
loadbootenv=load mmc $sdbootdev:$partid ${loadbootenv_addr} ${bootenv}
loadbootenv_addr=0x00100000
modeboot=qspiboot
nc=setenv stdout nc;setenv stdin nc;
netboot=tftpboot ${netstart} ${kernel_img} && bootm
netstart=0x10000000
psserial0=setenv stdout ttyPS0;setenv stdin ttyPS0
sd_uEnvtxt_existence_test=test -e mmc $sdbootdev:$partid /uEnv.txt
sd_update_boot=echo Updating boot from SD; mmcinfo && fatload mmc ${sdbootdev}:1 ${clobstart} ${boot_img} && run install_boot
sd_update_dtb=echo Updating dtb from SD; mmcinfo && fatload mmc ${sdbootdev}:1 ${clobstart} ${dtb_img} && run install_dtb
sd_update_jffs2=echo Updating jffs2 from SD; mmcinfo && fatload mmc ${sdbootdev}:1 ${clobstart} ${jffs2_img} && run install_jffs2
sd_update_kernel=echo Updating kernel from SD; mmcinfo && fatload mmc ${sdbootdev}:1 ${clobstart} ${kernel_img} && run install_kernel
sdbootdev=0
serial=setenv stdout serial;setenv stdin serial
serverip=192.168.1.36
setup=setenv partid auto
soc=zynqmp
stderr=serial@ff000000
stdin=serial@ff000000
stdout=serial@ff000000
test_crc=if imi ${clobstart}; then run test_img; else echo ${img} Bad CRC - ${img} is NOT UPDATED; fi
test_img=setenv var "if test ${filesize} -gt ${psize}; then run fault; else run ${installcmd}; fi"; run var; setenv var
thor_mmc=run dfu_mmc_info && thordown 0 mmc 0
thor_ram=run dfu_ram_info && thordown 0 ram 0
uenvboot=if run sd_uEnvtxt_existence_test; then run loadbootenv; echo Loaded environment from ${bootenv}; run importbootenv; fi; if test -n $uenvcmd; then echo Running uenvcmd ...; run uenvcmd; fi
update_boot=setenv img boot; setenv psize ${bootsize}; setenv installcmd "install_boot"; run load_boot test_img; setenv img; setenv psize; setenv installcmd
update_dtb=setenv img dtb; setenv psize ${dtbsize}; setenv installcmd "install_dtb"; run load_dtb test_img; setenv img; setenv psize; setenv installcmd
update_jffs2=setenv img jffs2; setenv psize ${jffs2size}; setenv installcmd "install_jffs2"; run load_jffs2 test_img; setenv img; setenv psize; setenv installcmd
update_kernel=setenv img kernel; setenv psize ${kernelsize}; setenv installcmd "install_kernel"; run load_kernel test_crc; setenv img; setenv psize; setenv installcmd
vendor=xilinx
Environment size: 3986/262140 bytes
Winston Jacob
Re: Wrong Image Format for bootm command ERROR: can't get kernel image (ZCU102, Petalinux 2018.1 & SDK 2018.1)
Hi @winston
What is the image type. Did you convert the image format to uImage?
petalinux-package --image -c kernel --format uImage
Best Regards
Shabbir
Hi @winston
Best Regards
Shabbir
Observer winston
Thanks for immediate reply Shabbir. I am using image.ub(Created by petalinux 2018.1). And I bind all the images to create Boot.bin,
and I am not used that command previously. I am going to try this command . After finishing I update you.
Winston
Newbie xqq1314
hi,bro!
             I have meet the same problem like you . Have you solved this problem?I create the uImage file but i don't know how to download it into qspi flash.Can you help me?
             Thank you so much!!
Newbie xqq1314
hi,bro!
I have meet the same problem . I create the uImage file but i don't know how to download it into qspi flash.Can you help me?
Thank you so much!!
Observer zosvitta
Could you please update your result?
I am also facing the same issue.
