Wrong address returned by mmap
I am using he AXI DMA (on an UltraZed EG board) to inject data into the DDR system and reading it from Linux.
The C code regarding this task is the following:
#define DDR_ADDR_LOW (uint32_t) 0x00000000
#define DDR_ADDR_HIGH (uint32_t) 0x1fffffff
#define SAXI_DMA_BASE_ADDR (uint32_t) 0x80000000
uint32_t *ddrp = NULL;
int32_t sh_mem_fd = open("/dev/mem", O_RDWR | O_SYNC);
saxi_addr = mmap(NULL, 4096, PROT_READ | PROT_WRITE, MAP_SHARED, sh_mem_fd, SAXI_DMA_BASE_ADDR);
ddrp = mmap(NULL, 4096, PROT_READ, MAP_SHARED, sh_mem_fd, DDR_ADDR_LOW);
This should be correct according to Vivado addresses memory map
The problem is the wrong address pointed to by ddrp as a result of the mmap function.
When I print the address pointed to ddrp
printf("ddrp = %p\n", ddrp);
it results to be
ddrp = 0xffffffffffffffff
which is obviously wrong.
The problem raised after enabling USB 3.0 support as detailed in my last post
https://forums.xilinx.com/t5/Embedded-Linux/USB-3-0-pendrive-not-recognized-petalinux-kernel-4-19-0-xilinx/m-p/1052994#M38719
Before that I could correctly mmap the DDR address to read AXI DMA data, so the whole code was working correctly.
Is there something I am missing on ? Could someone give an hint about this ?
Thanks in advance,
s.
Re: Wrong address returned by mmap
Any useful hint on this problem ?
