XAPP1078 + my kernel image on Zynq 702
I have problem with work of the sample XAPP1078 (Linux+Bare-metal AMP) when using my build of linux kernel as described in Wiki.  In this case, after command
./rwmem.elf 0xfffffff0 0x30000000
application on CPU1 is not started. But if I use precompiled kernel, all works fine. I do next steps to build kernel:
git clone git://git.xilinx.com/linux-xlnx.git
cd linux-xlnx
git pull origin xilinx-14.3-build2
make ARCH=arm xilinx_zynq_defconfig
make ARCH=arm UIMAGE_LOADADDR=0x8000 uImage
after loading Zinq:
uname -a
Linux 192.168.0.161 3.8.0-xilinx #3 SMP PREEMPT Thu May 30 11:04:12 NOVT 2013 armv7l GNU/Linux
How I have to build kernel for XAPP1078 sample?
You are using the newer version of kernel. You need to
git checkout -b xilinx-v14.3-build2 xilinx-v14.3-build2
in order to get the older version of kernel.
The newer 3.8 kernel starts up CPU1 differently and pulls CPU1 away from the wfe loop. You could modify the kernel (as documented in the following link under Running XAPP1078 on the ZC706 Board) to instruct the kernel to send CPU1 back to the wfe loop.
Take a look at http://www.wiki.xilinx.com/XAPP1078+Latest+Information
You didn't mention the devicetree.
Don't forget to make the bootarg changes and memory change to the devicetree before compiling the devicetree.
There is a file in the proc file system that will tell you how many processors are running. You should see only one because of the bootarg changes.
I use the same devicetree.dtb for precompiled kernel and my kernel. I replaced only uImage file in SD card.
Working kernel looks like:
uname -a
Linux 192.168.0.161 3.5.0-14.3-build2-25241-gaa09283 #2 SMP PREEMPT Mon Oct 29 15:29:56 EDT 2012 armv7l GNU/Linux
