Visitor charlie5902
XDMA Petalinux basics questions
Ok so I've read through most of the posts from folks having trouble getting started with Axi DMA and DMA Engine in Petalinux. I am still missing something.
My hardware has an AXI DMA with TX and RX connected in loopback and everything connected. axi_dma_o and axi_dma_1 both show up properly in the device tree.
I want to be able to request a channel from a generic client driver. I have read the DMA Engine API docs and looked at the axi dma test example.
What exactly do I need to do to get success in my driver for requesting a channel?
I suspect I am missing a device tree entry with a .compatible entry for my driver - is that necessary for a generic client driver?
If I need a device tree entry for my driver - what are the contents needed for the entry?
This is Vivado/Petalinux  2018.2.
Re: XDMA Petalinux basics questions
Hi @charlie5902,
Device-tree contents depends on how you write the driver and pass property values to driver.
Compatible string is not 100% mandatory it is just to specify the manufacture and model(device, ip or peripheral) associated with drivers.
I have attached the attached the 2018.1 axi-dma project-spec files for ZCU102 board you can use as reference. For 2018.2 it will be the same no changes in device-tree.
Sandeep
Hi @charlie5902,
Sandeep
Visitor charlie5902
Thanks so much for the great info and reference files.
I am getting closer but still not able to request my channels in my driver. I have the device tree mods as specified and requesting the channel names as specified in the device tree but dma_request_slave_channel returns NULL.
To try to troubleshoot more, I've enabled the axidmatest module. I've added the device tree node to enable it, build and when I load the module I get a segmentation fault in the probe function.
Any suggestions on how to proceed to troubleshoot this?
Visitor charlie5902
So continuing to plug away at this - I am now able to request channels in my driver. I am suspecting failure was because I did not have the DMA interrupt connected in my hardware design. I connected it up, rebuilt and everything seems to be better now.
On to the next step of setting up a dma transaction - hoping things are going to get easier from here!
Thanks for help so far!!
