XILINX zynq picozed XCz030
Hi Folks,
I have a XILINX zynq  picozed XCz030 board, for which I want to build the uboot, linux and dtb, but I am not able to find the defconfig files for it.
Can anyone point me to the linux/uboot defconfig files and also how to build dtb file for it.
Cheers,
-Sagar
Re: XILINX zynq picozed XCz030
@hugarsagar
I have seen a U-boot patch for adding the Picozed board.Refer to the link http://lists.denx.de/pipermail/u-boot/2015-April/210826.html
SYS_CONFIG_NAME
 	default "zynq_zed" if TARGET_ZYNQ_ZED
 	default "zynq_microzed" if TARGET_ZYNQ_MICROZED
+	default "zynq_picozed" if TARGET_ZYNQ_PICOZED
 	default "zynq_zc70x" if TARGET_ZYNQ_ZC70X
 	default "zynq_zc770" if TARGET_ZYNQ_ZC770
 	default "zynq_zybo" if TARGET_ZYNQ_ZYBO
Try cloning the latest U-boot from git and see if you are able to configure for Picozed.
Hope this helps.
Achutha
@hugarsagar
Do you have a chance to verify this?
Achutha
Thanks for the response, It works.
Sagar
@hugarsagar
Thanks for updating.
Mark the post as solution so that it helps other looking for similar info.
Achutha
