XSDK GUI does not start
Following this guideline to build pmu_fw. When I execute
xsdk -workspace . &
Nothing happens. No GUI comes up.
****** Xilinx Software Development Kit
****** SDK v2016.4 (64-bit)
  **** SW Build 1756540 on Mon Jan 23 19:11:19 MST 2017
    ** Copyright 1986-2016 Xilinx, Inc. All Rights Reserved.
Launching SDK with command /home/user/myfs/pkg/Xilinx/SDK/2016.4/eclipse/lnx64.o/eclipse -data . -vmargs -Xms64m -Xmx512m -Dorg.eclipse.swt.internal.gtk.cairoGraphics=false
[1]+  Done                    xsdk -workspace .
What is the issue and how do I fix it?
Any help is appreciated.
Re: XSDK GUI does not start
Need to install java JRE and set SWT_GTK3=0, i.e
sudo apt-get install default-jre
export SWT_GTK3=0
@rail.shafigulin
Launch without the ampersand (&) so you can see the messages. Optionally, redirect them to a pipe if they are too much.
xsdk -workspace . > log.txt 2>&1
 Also in the current directory you should have new files (list and sort by timestamp `ls -ltr`) - they should contain more information.
Here is what I get in log.txt after running xsdk -workspace . > log.txt 2>&1
@rail.shafigulin Any files in the current directory?
drwxr-xr-x 6 user user 4096 Aug  1 13:43 ./
drwxr-xr-x 3 user user 4096 Mar 21 18:07 ../
-rw-rw-r-- 1 user user  366 Aug  1 13:43 log.txt
drwxrwxr-x 3 user user 4096 Aug  1 11:16 .metadata/
drwxr-xr-x 3 user user 4096 Mar 21 18:07 pmu_fw/
drwxr-xr-x 2 user user 4096 Mar 21 18:07 pmu_fw_bsp/
drwxr-xr-x 2 user user 4096 Mar 21 18:07 zcu102_base_trd_wrapper_hw_platform_0/
export SWT_GTK3=0
