movax
Xilinx AXI GPIO Kernel Hang / Not Working Zynq UltraScale+
Hi all
I have been struggling for the past several hours getting a simple design with AXI GPIO on the UltraScale+ (Ultra96 board) running. The kernel hangs early in boot, usually after reporting the console has been enabled. In working boots (more on that later), the following message is the fpga-region manager.
I have several combinations of errors that I cause that seem to stem from a mis-configuration of the AXI GPIO device-tree entry. When I specify the full entry, as such:
	axi_gpio_0: gpio@a0000000 {
		#gpio-cells = <2>;
		clock-names = "s_axi_aclk";
		clocks = <&zynqmp_clk 71>;
		compatible = "xlnx,axi-gpio-2.0", "xlnx,xps-gpio-1.00.a";
		gpio-controller ;
		reg = <0x0 0xa0000000 0x0 0x1000>;
		xlnx,all-inputs = <0x0>;
		xlnx,all-inputs-2 = <0x0>;
		xlnx,all-outputs = <0x0>;
		xlnx,all-outputs-2 = <0x0>;
		xlnx,dout-default = <0x00000000>;
		xlnx,dout-default-2 = <0x00000000>;
		xlnx,gpio-width = <0xc>;
		xlnx,gpio2-width = <0xc>;
		xlnx,interrupt-present = <0x0>;
		xlnx,is-dual = <0x1>;
		xlnx,tri-default = <0xFFFFFFFF>;
		xlnx,tri-default-2 = <0xFFFFFFFF>;
	axi_gpio_1: gpio@a0001000 {
		#gpio-cells = <3>;
		gpio-controller ;
		reg = <0x0 0xa0001000 0x0 0x1000>;
		xlnx,gpio-width = <0x2>;
		xlnx,gpio2-width = <0x20>;
		xlnx,is-dual = <0x0>;
The kernel will hang, and I will see errors related to the GPIO as such:
    1.298262] xilinx-gpio a0000000.gpio: Input clock not found
[    1.298314] xilinx-gpio a0001000.gpio: Input clock not found
Things I have tried over the past 6-7 hours:
  • Passing clk_ignore_unused on every boot in bootargs
  • Verified in psu_init.c that PL0 clock configuration was not getting clobbered
  • Using v2019.1 Git tags of everything. Using stock DTSI + Common Clock Framework DTSI
  • Trying a fixed clock definition in device-tree, kernel still hangs
  • Checking debugfs kernel output on clocks, can't make sense of it to see if PL0 is actually active
  • If I remove clock-names, but keep clocks, the kernel will boot and the GPIO peripherals will not work, again reporting an input clock error.
  • If I keep clock-names, but remove clocks entry, the kernel will boot and the GPIO peripheral will not work, again reporting an input clock error
  • Have tried placing the PL stuff inside a separate amba_pl entry, like the DTG does
  • Tried feeding the device-tree entries for axi_gpio with other clocks like LPD_LSCLK
  • Have built FSBL, U-Boot, PMU all from source
  • Software Version: Vivado 2019.1
The PL just has two axi_gpio instances in it, so I'm really disheartened at why this is being so painful to work with. I have not managed to get a configuration where I can talk to the peripherals in Linux.
I was suspecting perhaps the PL clocks are getting turned off, but I am using the CCF and I see all fabric clocks as "okay" in the DTS. The GPIO drivers seem to load very early in the kernel, long before the platform management drivers; could that be why it is breaking?
Threads I have found / read:
A kernel hung run:
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd034]
[    0.000000] Linux version 4.19.0 (movax@whistler) (gcc version 8.2.0 (GCC)) #1 SMP Wed Jun 26 22:19:26 PDT 2019
[    0.000000] Machine model: Warhol ZCU100 RevC
[    0.000000] earlycon: cdns0 at MMIO 0x00000000ff010000 (options '115200n8')
[    0.000000] bootconsole [cdns0] enabled
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] efi: UEFI not found.
[    0.000000] cma: Reserved 256 MiB at 0x0000000070000000
[    0.000000] psci: probing for conduit method from DT.
[    0.000000] psci: PSCIv1.1 detected in firmware.
[    0.000000] psci: Using standard PSCI v0.2 function IDs
[    0.000000] psci: MIGRATE_INFO_TYPE not supported.
[    0.000000] psci: SMC Calling Convention v1.1
[    0.000000] random: get_random_bytes called from start_kernel+0x94/0x3f8 with crng_init=0
[    0.000000] percpu: Embedded 22 pages/cpu @(____ptrval____) s52504 r8192 d29416 u90112
[    0.000000] Detected VIPT I-cache on CPU0
[    0.000000] CPU features: enabling workaround for ARM erratum 845719
[    0.000000] Speculative Store Bypass Disable mitigation not required
[    0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 517120
[    0.000000] Kernel command line: earlycon clk_ignore_unused root=/dev/mmcblk0p2 rw rootwait
[    0.000000] Dentry cache hash table entries: 262144 (order: 9, 2097152 bytes)
[    0.000000] Inode-cache hash table entries: 131072 (order: 8, 1048576 bytes)
[    0.000000] Memory: 1785040K/2097152K available (10428K kernel code, 618K rwdata, 5212K rodata, 768K init, 305K bss, 49968K reserved, 262144K cma-reserved)
[    0.000000] rcu: Hierarchical RCU implementation.
[    0.000000] rcu:     RCU event tracing is enabled.
[    0.000000] rcu:     RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[    0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[    0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[    0.000000] GIC: Adjusting CPU interface base to 0x00000000f902f000
[    0.000000] GIC: Using split EOI/Deactivate mode
[    0.000000] arch_timer: cp15 timer(s) running at 100.00MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x171024e7e0, max_idle_ns: 440795205315 ns
[    0.000004] sched_clock: 56 bits at 100MHz, resolution 10ns, wraps every 4398046511100ns
[    0.008339] Console: colour dummy device 80x25
[    0.012462] console [tty0] enabled
[    0.015827] bootconsole [cdns0] disabled
[    0.019742] Calibrating delay loop (skipped), value calculated using timer frequency.. 200.00 BogoMIPS (lpj=400000)
[    0.019757] pid_max: default: 32768 minimum: 301
[    0.019884] Mount-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.019902] Mountpoint-cache hash table entries: 4096 (order: 3, 32768 bytes)
[    0.020784] ASID allocator initialised with 32768 entries
[    0.020845] rcu: Hierarchical SRCU implementation.
[    0.021164] EFI services will not be available.
[    0.021307] smp: Bringing up secondary CPUs ...
[    0.021632] Detected VIPT I-cache on CPU1
[    0.021671] CPU1: Booted secondary processor 0x0000000001 [0x410fd034]
[    0.022019] Detected VIPT I-cache on CPU2
[    0.022040] CPU2: Booted secondary processor 0x0000000002 [0x410fd034]
[    0.022355] Detected VIPT I-cache on CPU3
[    0.022375] CPU3: Booted secondary processor 0x0000000003 [0x410fd034]
[    0.022420] smp: Brought up 1 node, 4 CPUs
[    0.022453] SMP: Total of 4 processors activated.
[    0.022462] CPU features: detected: 32-bit EL0 Support
[    0.024885] CPU: All CPU(s) started at EL2
[    0.024903] alternatives: patching kernel code
[    0.026173] devtmpfs: initialized
[    0.030567] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[    0.030596] futex hash table entries: 1024 (order: 4, 65536 bytes)
[    0.036874] xor: measuring software checksum speed
[    0.076994]    8regs     :  2375.000 MB/sec
[    0.117023]    8regs_prefetch:  2052.000 MB/sec
[    0.157055]    32regs    :  2725.000 MB/sec
[    0.197087]    32regs_prefetch:  2309.000 MB/sec
[    0.197095] xor: using function: 32regs (2725.000 MB/sec)
[    0.197113] pinctrl core: initialized pinctrl subsystem
[    0.197964] NET: Registered protocol family 16
[    0.198320] audit: initializing netlink subsys (disabled)
[    0.198396] audit: type=2000 audit(0.188:1): state=initialized audit_enabled=0 res=1
[    0.198871] cpuidle: using governor menu
[    0.199014] vdso: 2 pages (1 code @ (____ptrval____), 1 data @ (____ptrval____))
[    0.199028] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[    0.199924] DMA: preallocated 256 KiB pool for atomic allocations
[    0.212465] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[    0.277252] raid6: int64x1  gen()   446 MB/s
[    0.345339] raid6: int64x1  xor()   487 MB/s
[    0.413350] raid6: int64x2  gen()   680 MB/s
[    0.481427] raid6: int64x2  xor()   602 MB/s
[    0.549451] raid6: int64x4  gen()   981 MB/s
[    0.617512] raid6: int64x4  xor()   735 MB/s
[    0.685569] raid6: int64x8  gen()  1183 MB/s
[    0.753613] raid6: int64x8  xor()   790 MB/s
[    0.821730] raid6: neonx1   gen()   736 MB/s
[    0.889738] raid6: neonx1   xor()   880 MB/s
[    0.957778] raid6: neonx2   gen()  1128 MB/s
[    1.025836] raid6: neonx2   xor()  1174 MB/s
[    1.093893] raid6: neonx4   gen()  1486 MB/s
[    1.161927] raid6: neonx4   xor()  1419 MB/s
[    1.229986] raid6: neonx8   gen()  1541 MB/s
[    1.298044] raid6: neonx8   xor()  1460 MB/s
[    1.298052] raid6: using algorithm neonx8 gen() 1541 MB/s
[    1.298060] raid6: .... xor() 1460 MB/s, rmw enabled
[    1.298068] raid6: using neon recovery algorithm
[    1.298262] xilinx-gpio a0000000.gpio: Input clock not found
[    1.299184] SCSI subsystem initialized
[    1.299420] usbcore: registered new interface driver usbfs
[    1.299464] usbcore: registered new interface driver hub
[    1.299507] usbcore: registered new device driver usb
[    1.299588] media: Linux media interface: v0.10
[    1.299622] videodev: Linux video capture interface: v2.00
[    1.299655] pps_core: LinuxPPS API ver. 1 registered
[    1.299664] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    1.299687] PTP clock support registered
[    1.299723] EDAC MC: Ver: 3.0.0
[    1.300178] zynqmp-ipi-mbox mailbox@ff990400: Probed ZynqMP IPI Mailbox driver.
[    1.300426] FPGA manager framework
[    1.300596] Advanced Linux Sound Architecture Driver Initialized.
[    1.301328] clocksource: Switched to clocksource arch_sys_counter
[    1.301427] VFS: Disk quotas dquot_6.6.0
[    1.301480] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[    1.307287] NET: Registered protocol family 2
[    1.307725] tcp_listen_portaddr_hash hash table entries: 1024 (order: 2, 16384 bytes)
[    1.307760] TCP established hash table entries: 16384 (order: 5, 131072 bytes)
[    1.307875] TCP bind hash table entries: 16384 (order: 6, 262144 bytes)
[    1.308205] TCP: Hash tables configured (established 16384 bind 16384)
[    1.308300] UDP hash table entries: 1024 (order: 3, 32768 bytes)
[    1.308345] UDP-Lite hash table entries: 1024 (order: 3, 32768 bytes)
[    1.308484] NET: Registered protocol family 1
[    1.308745] RPC: Registered named UNIX socket transport module.
[    1.308755] RPC: Registered udp transport module.
[    1.308762] RPC: Registered tcp transport module.
[    1.308769] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    1.309713] hw perfevents: no interrupt-affinity property for /pmu, guessing.
[    1.309885] hw perfevents: enabled with armv8_pmuv3 PMU driver, 7 counters available
[    1.310860] Initialise system trusted keyrings
[    1.310959] workingset: timestamp_bits=62 max_order=19 bucket_order=0
[    1.311736] NFS: Registering the id_resolver key type
[    1.311754] Key type id_resolver registered
[    1.311762] Key type id_legacy registered
[    1.311776] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[    1.311798] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    2.394171] NET: Registered protocol family 38
[    2.452363] Key type asymmetric registered
[    2.452373] Asymmetric key parser 'x509' registered
[    2.452428] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    2.452442] io scheduler noop registered
[    2.452450] io scheduler deadline registered
[    2.452492] io scheduler cfq registered (default)
[    2.452502] io scheduler mq-deadline registered
[    2.452510] io scheduler kyber registered
[    2.483482] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    2.486852] cacheinfo: Unable to detect cache hierarchy for CPU 0
[    2.492057] brd: module loaded
[    2.496948] loop: module loaded
[    2.497919] mtdoops: mtd device (mtddev=name/number) must be supplied
[    2.499461] libphy: Fixed MDIO Bus: probed
[    2.500963] tun: Universal TUN/TAP device driver, 1.6
[    2.501168] CAN device driver interface
[    2.501182] sja1000 CAN netdevice driver
[    2.502135] usbcore: registered new interface driver asix
[    2.502180] usbcore: registered new interface driver ax88179_178a
[    2.502217] usbcore: registered new interface driver cdc_ether
[    2.502249] usbcore: registered new interface driver net1080
[    2.502282] usbcore: registered new interface driver cdc_subset
[    2.502314] usbcore: registered new interface driver zaurus
[    2.502361] usbcore: registered new interface driver cdc_ncm
[    2.503157] usbcore: registered new interface driver uas
[    2.503204] usbcore: registered new interface driver usb-storage
[    2.503901] rtc_zynqmp ffa60000.rtc: rtc core: registered ffa60000.rtc as rtc0
[    2.503969] i2c /dev entries driver
[    2.505482] usbcore: registered new interface driver uvcvideo
[    2.505495] USB Video Class driver (1.1.1)
[    2.506243] EDAC MC: ECC not enabled
[    2.506410] EDAC DEVICE0: Giving out device to module zynqmp-ocm-edac controller zynqmp_ocm: DEV ff960000.memory-controller (INTERRUPT)
[    2.507243] sdhci: Secure Digital Host Controller Interface driver
[    2.507254] sdhci: Copyright(c) Pierre Ossman
[    2.507261] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.507657] ledtrig-cpu: registered to indicate activity on CPUs
[    2.507714] zynqmp_firmware_probe Platform Management API v1.1
[    2.507725] zynqmp_firmware_probe Trustzone version v1.0
[    2.510768] zynqmp-pinctrl firmware:zynqmp-firmware:pinctrl: zynqmp pinctrl initialized
[    2.533019] zynqmp_clk_mux_get_parent() getparent failed for clock: lpd_wdt, ret = -22
[    2.533621] alg: No test for xilinx-zynqmp-aes (zynqmp-aes)
[    2.533645] zynqmp_aes zynqmp_aes: AES Successfully Registered
[    2.533645]
[    2.533832] alg: No test for xilinx-keccak-384 (zynqmp-keccak-384)
[    2.534003] alg: No test for xilinx-zynqmp-rsa (zynqmp-rsa)
[    2.534247] usbcore: registered new interface driver usbhid
[    2.534256] usbhid: USB HID core driver
[    2.536235] fpga_manager fpga0: Xilinx ZynqMP FPGA Manager registered
[    2.536644] usbcore: registered new interface driver snd-usb-audio
[    2.537596] pktgen: Packet Generator for packet performance testing. Version: 2.75
[    2.538068] Initializing XFRM netlink socket
[    2.538168] NET: Registered protocol family 10
[    2.538633] Segment Routing with IPv6
[    2.538741] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    2.539143] NET: Registered protocol family 17
[    2.539161] NET: Registered protocol family 15
[    2.539183] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[    2.539243] can: controller area network core (rev 20170425 abi 9)
[    2.539284] NET: Registered protocol family 29
[    2.539294] can: raw protocol (rev 20170425)
[    2.539302] can: broadcast manager protocol (rev 20170425 t)
[    2.539313] can: netlink gateway (rev 20170425) max_hops=1
[    2.539449] 9pnet: Installing 9P2000 support
[    2.539477] Key type dns_resolver registered
[    2.539972] registered taskstats version 1
[    2.539981] Loading compiled-in X.509 certificates
[    2.540362] Btrfs loaded, crc32c=crc32c-generic
[    2.548322] ff000000.serial: ttyPS1 at MMIO 0xff000000 (irq = 24, base_baud = 6249999) is a xuartps
[    2.548521] serial serial0: tty port ttyPS0 registered
[    2.548942] ff010000.serial: ttyPS0 at MMIO 0xff010000 (irq = 25, base_baud = 6249999) is a xuartps
[    3.665748] console [ttyPS0] enabled
movax
Found the issue; Vivado had generated and connected a pl_resetn signal from the PS instantiation block to the reset input on the processing system reset block. It was sourced from an EMIO GPIO and was uninitialized in the PS init file. Getting rid of that signal solved the problem.
movax
Thanks for clearing this out of the spam filter! Please feel free to close my repost, I just wanted to get the post up ASAP. That thread is here: https://forums.xilinx.com/t5/Embedded-Linux/Xilinx-AXI-GPIO-Kernel-Hang-Not-Working-Zynq-UltraScale-REPOST/td-p/989055
I've been noodling on it all day...is it a later access by the kernel attempting to setup the sysfs GPIO interface with the AXI GPIO peripheral that is unclocked? I will post screenshots of my Block Design as well and can upload my design files. Using buildroot to make my kernel and userspace, and compiled FSBL, U-Boot, ATF and PMUFW from xilinx-v2019.1 tags.
movax
Hi all —
For a properly configured PL clock (i.e. PL0 operating as an output to the fabric), what should I expect to see in debugfs when I look at the clk_summary?
abhinayp
Hi @movax,
Please check the below link
https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18841664/porting?showComments=true&showCommentArea=true
Best Regards
Abhinay PS
Give kudos to a post which you think is helpful and reply oriented.
movax
Hi Abhinay —
Thanks, I will give that a try after this holiday weekend. From the link you sent, are you suggesting that I need to add a "clock-generator" entry to my DT in order for the output clock 71 / the other PS-PL clocks to be "activated"? Wouldn't my "clk_ignore_unused" option passed to kernel leave the clocks in the state the FSBL (which should turn them on) / U-Boot (which should not touch them) left them in?
I'm hoping what you suggested works to fix my problem but I'm also curious to understand what exactly was the issue / root-cause it (i.e. if it is no clock, then it probably hung on a memory access, so why is there no clock?)
movax
Hi Abhinay,
I am not using the clocking wizard, so I think that link may not apply to me as the clock manager is configured in the DTSI I have included.
However, I just noticed that Vivado gave me memory address of 0xA0000000 and 0xA0001000 for the peripherals. In Table 10-1, this is assigned to the VCU. Is this OK? I am using the Ultra96 which has a ZU3EG device with no VCU. In the silicon, is this space given to M_AXI_HPM0_FPD as the Table suggests and I get 192MB + 64MB for a full 256MB?
movax
Here is my block diagram as well. This is Case 1 from this page (https://xilinx-wiki.atlassian.net/wiki/spaces/A/pages/18842336/DTG+Common+clock+framework) and I have my device-tree specifying the clock-name as "s_axi_aclk" and the clock source being clock controller output 0x71, PL0.
movax
With printk debugging, I tracked down where I'm hanging, in xgpio_save_regs on attempting memory writes. I added some code to print out what address it's trying to hit, and it does not seem correct:
[    3.629265] PASSED xgpio_of_probe 666
[    3.632932] PASSED xgpio_of_probe 684
[    3.636595] PASSED xgpio_of_probe 693
[    3.640242] PASSED xgpio_of_probe 698
[    3.643902] PASSED of_mm_gpiochip_add_data 466
[    3.648340] PASSED of_mm_gpiochip_add_data 472
[    3.652802] PASSED of_mm_gpiochip_add_data 481
[    3.657243] PASSED xgpio_save_regs 251
[    3.660984] mm_gc->regs: 0x9215000
[    3.664377] mm_gc->regs: 0xFFFFFF8009215000
[    3.668553] PASSED xgpio_save_regs 267
(The line numbers will not match exactly because I added statements, of course). So unless the address I'm getting there is a virtual one (which it should not be), that sure doesn't look like 0xA000xxxx to me. Additionally, I changed the reg parameters on the device-tree intentionally and still get the same value here, so either it's from casting iomem to u32/u64 incorrectly or something else is up.
movax
I've confirmed with devmem that the PL clock registers are set correctly and FPGA has been configured. As this point it seems to be hanging on the memory access to fabric, which is usually indicative of a broken clock I think, or some other issue. Any other ideas here?
movax
