Xilinx Emaclite Time Stamping - PTP4L
I am using the Xilinx Emaclite driver for an ethernet port connected through FMC. This FMC Ethernet modules has a DP83640 PHY, which supports Hardware phy level time stamping. I added the following lines to the emaclite driver in order to execute the ptp4l:
static int xemaclite_ioctl(struct net_device *ndev, struct ifreq *rq, int cmd)
        if (!netif_running(ndev))
                return -EINVAL;
        if (!ndev->phydev)
                return -EINVAL;
        return phy_mii_ioctl(ndev->phydev, rq, cmd);
However, when I execute ptp4l I get the following error:
ptp4l[1138.006]: timed out while polling for tx timestamp
ptp4l[1138.006]: increasing tx_timestamp_timeout may correct this issue, but it is likely caused by a driver bug
ptp4l[1138.006]: port 1: send sync failed
ptp4l[1138.006]: port 1: MASTER to FAULTY on FAULT_DETECTED (FT_UNSPECIFIED)
It fails in the poll() and I do not know why. Do I need to modify more the emaclite driver?
