yugdesign
Xilinx Petalinux Flow not creating pcw.dtsi file
I am using Petalinux 18.2 and following the steps to create a petalinux build using hdf file for custom Board. I am trying to use jtag boot with prebuilt 3. I am not finding the pcw.dtsi generated as a flow described in the manual. This file gets generated only when exclusive - c device-tree option is provided as apart of petalinux build. I am not sure if the flow is broken here. Also during JTAG boot I need to download the bit file through sdk and do the ps-init through sdk. Can somebody post the exact flow to follow.
