Xilinx Qemu - Fault_injection error
I am using petalinux qemu and trying to inject faults through QMP during execution. I want to read/write to a memory location using the QMP python API.
I am following the steps from https://github.com/Xilinx/qemu/blob/master/docs/fault_injection.txt.
On QEMU side, i am adding -S -qmp unix:/qmp-sock,server to my boot command. And in another terminal trying to use the fault_injection script from qmp folder.
I get an error: Could not connect to /qmp-sock.
Has anyone else tried this and what can i do to make the fault_injection work?
Thank You,
Khalida.
Re: Xilinx Qemu - Fault_injection error
Hi @khalida.begum
Do you have the /qmp-sock existing. If not try creating this directory and see if you can connect to qmp-socket
Best Regards
Shabbir
Hi @khalida.begum
Best Regards
Shabbir
Hi @khalida.begum
At petalinux side, you have to run this command:
 petalinux-boot --qemu --kernel --qemu-args "-S -qmp unix:/qmp-sock,server"
Best Regards
Shabbir
