shahanujs
Xilinx Zynq UltraScale+ MPSoC ZU3EG A484 apt-get command not found
I have Xilinx Zynq UltraScale+ MPSoC ZU3EG A484:
I downloaded factory reset Linux which is approximately 16GB size of OS. I tried connecting my device with internet but It says apt-get command not found, I also tried Yum install and it says yum command not found. Please advise how to work with this Linux OS where I cannot download or install any 3rd party software or tools.I also downloaded PYNQ 2019 version and that one has the same problem I cannot download anything. I am not sure what are this OS for? How can I do Linux development with tools?
Please advise on proper internet connectivity or Linux OS.
watari
Hi @shahanujs
The following URL might be helpful for you, if you build linux kernel by yourself.
https://forums.xilinx.com/t5/Embedded-Linux/ZCU102-ubuntu-desktop-using-Petalinux-2019-1/m-p/1037244#M39478
Or the following URL is helpful for you, if you use debian instead of ubuntu.
https://github.com/ikwzm/ZynqMP-FPGA-Linux
Best regards,
chaoz
Hi @shahanujs
By saying "I downloaded factory reset Linux which is approximately 16GB size of OS" -- what kind of Linux rootfs are you using? Can you provide the source or link?
Tipycally embedded Linux don't support package management(apt-get/yum...), these are only supported by Desk OS like Ubuntu/RedHat...
You can get Ubunut on Zynq also but this is not supported officially by Xilinx.
shahanujs
Hello Thank you for the reply. I am fairly new to this linux world and Zynq. The OS i downloaded was found under following link:
https://www.96boards.org/documentation/consumer/ultra96/ultra96-v2/downloads/
I used Linux (pre-built).
Can you please share the link for the ubuntu linux for zynq, i know it is not officially approved by zynq but i have no other choice.
Thank you very much and appreciated for the help.
watari
Hi @shahanujs
Best regards,
shahanujs
Thank you for the infromation. I have never created Linux Kernel but guess i will learn from now on.
appreciated.
