Anonymous
Not applicable
Xilinx linux in Zynq: no ethernet
I created a project including only the Zynq.
DTS file attached.
I can boot linux (see attached log).
But
zynq> ifconfig
zynq>
How to activate the ethernet?
Thanks in advance,
Max
Tags (3)
Anonymous
Not applicable
The problem was due to wrong clock settings
Solution here.
sorenb
What does ifconfig -a say?
johnmcd
I don't see a phy in your devicetree. Here's an example:
&gem0 {
    status = "okay";
    phy-mode = "rgmii-id";
    phy-handle = <&phy0>;
    phy0: phy@7 {
        reg = <7>;
Anonymous
Not applicable
With the original devicetree
zynq> ifconfig -a
lo        Link encap:Local Loopback
          LOOPBACK  MTU:65536  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
 Adding phy, as suggested by John
zynq> ifconfig -a
eth0      Link encap:Ethernet  HWaddr 00:0A:35:00:01:22
          BROADCAST MULTICAST  MTU:1500  Metric:1
          collisions:0 txqueuelen:1000
          Interrupt:54 Base address:0xb000
Anonymous
Not applicable
And why the procedure described here didn't generate the full devicetree (including eth)?
j.herbert1
Yes, generating the devicetree for ethernet simply doesn't work for me.
It gave me this:
&gem0 {
	local-mac-address = [00 0a 35 00 00 00];
	status = "okay";
	xlnx,ptp-enet-clock = <0x6750918>;
	ps7_ethernet_0_mdio: mdio {
		#address-cells = <1>;
		#size-cells = <0>;
But I needed this for it to actually work
&gem0 {
	status = "okay";
	xlnx,eth-mode = <0x1>;
	xlnx,has-mdio = <0x1>;
		#size-cells = <0>;
		phy0: phy@1 {
			compatible = "realtek,RTL8211E";
			device_type = "ethernet-phy";
			reg = <1>;
Anonymous
Not applicable
Solution here.
