Visitor miladmoo7
[Yocto] Getting framebuffer and video out of Displayport on ZynqMP
Hi there.
I'm using Yocto to build linux operating systems for ZynqMP. I've been able to build a core-image-x11 image and boot the OS. However when I try to run "xinit" command to start the X, it says no /dev/fb0 is found which means there is no fb0 in /dev/.
I was wondering if you could walk me through the right procedure in order to get video output from the display port. Primarily how to build a /dev/fb0 entity and how to redirect the video stream using Mali 400 GPU.
I did some digging and it seems I need to add Xilinx DRM driver, Mali GPU driver and some nodes in the devicetree and I'm not sure anymore how it will work out.
I am almost clueless about the situation and I would be more than grateful if someone could help.
Thanks in advance.
Re: [Yocto] Getting framebuffer and video out of Displayport on ZynqMP
I'm also doing some similar work.
To enable Xilinx DRM driver you need to run petalinux-config -c kernel, and enable it in Device Drivers->Graphics support->Xilinx DRM
There is also an option "ARM Mali Display Processor" under the same config hierachy. I guess you can try enable that too.
Hope it helped .
Kang
Visitor miladmoo7
Thanks for your answer.
I am trying to avoid meta-petalinux and get everything working through Yocto. Is there anyway that I could add Xilinx DRM to my linux-yocto kernel? Oh and also adding Xilinx DRM will create the /dev/fb0/ entity for me or I need to do some more?
Thanks again.
