Yocto Project BSP updated for latest Xilnx git
I updated https://github.com/balister/meta-zynq to use the latest master revs in the Xilinx git server. (And fixed the repo name change).
If you want to modify things in this layer, create a new layer and use bbappends to modify the kernel. I'll be glad to atke patches to this layer that improve the kernel on the zc702 and zedboard.
Things I would like to add:
 * Build fsbl and run the bootgen to make the BOOT.BIN file.
 * Support for zedboard
 * Support building ramdisk images.
I've also posted some files built from this in my Dropbox:
 http://dl.dropbox.com/u/14618236/BOOT.BIN-zc702
 http://dl.dropbox.com/u/14618236/uImage-zynq-zc702.bin
 http://dl.dropbox.com/u/14618236/uImage-zc702-sd.dtb
 http://dl.dropbox.com/u/14618236/zc702-proto-image-zynq-zc702-20130208154957.rootfs.tar.gz
These where built via the process described. Hopefully, Xilinx is OK with me publishing a BOOT.BIN with a fsbl built from the SDK. My GPL compliance strategy is to remove the downloads if anyone asks for the exact sources instead of building their own :)
Re: Yocto Project BSP updated for latest Xilnx git
Hey
When I build a OS based in the distribution open embedded yocto I generate many files in the directory /home/eukrea/Bureau/oe-core/build/tmp-eglibc/deploy/images/ when I want create zynq image with the files generated how I choose the value of the offset in ths Xilinx Tools-> Programm flash ? I want programme the zedboard with spi flash ?
What files I need choose in the directory images. I take screenshots you can see the pictures in the file attached.
Best Regards.
