Yocto build issues
    following these steps at this link
http://www.wiki.xilinx.com/Yocto+OSL+Image+build
[A] is this command correct ?
source setupsdk
or it should be
source setup sdk ?
[B] what about this command ?
source pkgsetup
i get this error
ERROR: Failed to obtain CodeSourcery toolchain version: Execution of '/proj/xbuilds/2016.2_daily_latest/installs/lin64/SDK/2016.2/gnu/aarch64/lin/aarch64-linux/bin/aarch64-linux-gnu-gcc -v' failed: command not found
ERROR: Make sure that MACHINE is set correctly in your local.conf and the toolchain supports aarch64.
ERROR:  OE-core's config sanity checker detected a potential misconfiguration.
    Either fix the cause of this error or at your own risk disable the checker (see sanity.conf).
    Following is the list of potential problems / advisories:
    Do not use Bitbake as root.
meanwhile, sh is on bash, all vivado tools are installed and up and running
RC
Hi @optivareddy
a) Once you synced the repo you should have there a file called setupsdk. So the wikipage is corrected you should use "source setupsdk"
b) Did you check if those paths are correct and are pointing to your SDK installation paths? Check the environmental variables listed in the wikipage and check if you set up them correctly before running the build system.
Ibai
    I don't see the folder [setupsdk] at all
root@dabba:~/yucto#
root@dabba:~/yucto#
root@dabba:~/yucto# pwd
/home/dabba/yucto
root@dabba:~/yucto#
root@dabba:~/yucto#
root@dabba:~/yucto# ls
pkgsetup  README.md  setup  sources
root@dabba:~/yucto#
root@dabba:~/yucto#
meanwhile, i am running the repo commands for version 2016.2
RC Reddy
stuck at this now,
                       any help i can get
root@root:~/yoctoxil/build# bitbake petlinux-minimal
Summary: There was 1 ERROR message shown, returning a non-zero exit code.
$ touch conf/sanity.conf
root@root:~/yoctoxil/build# MACHINE=zcu102-zynqmp bitbake petalinux-minimal
Parsing recipes: 25% |############################
finally this helped
solution at this link
https://github.com/gmacario/easy-build/tree/master/build-yocto
Added command: touch conf/sanity.conf
