Visitor portolan
Yocto not working
I tried building linux-xilinx for zedboard using Yocto, in a configuration already verified for BeagleBone.
I addedd the "meta-xilinx" to the Yocto "poky" directory, and added it to the BB layers. Anyway when I run bitbake I get the following error:
$ bitbake  meta-toolchain
WARNING: Host distribution "Debian-7.5" has not been validated with this version of the build system; you may possibly experience unexpected failures. It is recommended that you use a tested distribution.
Loading cache: 100% |############################################################################################################| ETA:  00:00:00
Loaded 1227 entries from dependency cache.
Parsing recipes: 100% |##########################################################################################################| Time: 00:00:00
Parsing of 868 .bb files complete (867 cached, 1 parsed). 1227 targets, 62 skipped, 0 masked, 0 errors.
ERROR: No recipes available for:
  /calcul/yocto/poky/meta-xilinx/recipes-devtools/gdb/gdb-cross_7.7.bbappend
  /calcul/yocto/poky/meta-xilinx/recipes-devtools/gdb/gdb_7.7.bbappend
  /calcul/yocto/poky/meta-xilinx/recipes-devtools/gdb/gdb-cross-canadian_7.7.bbappend
  /calcul/yocto/poky/meta-xilinx/recipes-devtools/qemu/qemu_2.0.0.bbappend
ERROR: Command execution failed: Exited with 1
Summary: There was 1 WARNING message shown.
Summary: There were 2 ERROR messages shown, returning a non-zero exit code.
What is it?
Michele
Re: Yocto not working
Hi Michelle,
This error can be easily resolved.
The meta-linux layer depends on the poky layer. The poky layer contains the main gdb-cross_x.x.bb recipe. A corresponding gdb-cross_x.x*.bbappend in the meta-xilinx layer will append to the recipes in the poky layer.
In this case, your poky and meta-xilinx branches may not be matched, and the gdb-cross_7.7.bb recipe might have been updated to a newer version, hence the .bbappend from the meta-xilinx layer fails for that particular recipe version.
A quick way to resolve this error is to either:
01. Check out the correct branch for both the poky and meta-xilinx layers.
The daisy branch is the latest (1.6), the dora branch is the previous release (1.5).
git checkout -b daisy --track remotes/origin/daisy
or
git checkout -b dora --track remotes/origin/dora
for both the poky and meta-xilinx layers, and then try to do a
$ bitbake core-image-minimal
This will build the toolchain, kernel and root filesystem.
02. Delete the offending *.bbappend from the meta-xilinx layer.
Review what the .bbappends are doing, though, since it might be adding support for microblaze to gdb, etc.
You should subscribe to the meta-xilinx mailing list, since most of the people from Xilinx who maintain the meta-xilinx layer actively participate on the mailing list.
https://lists.yoctoproject.org/listinfo/meta-xilinx
Let me know how it goes.
Elvis Dowson
Hi Michelle,
or
Elvis Dowson
Visitor portolan
Thanks Elvis,
I switched the meta-xilinx layer to daisy branch (like poky) and the compilation is launched correctly.
Michele
